You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Hoover Constellation 822
Casing parts.
This 822 motor is a different beast to the 867A I restored a few months ago.
Much larger and more solid then the other one.
Well that’s it for now, next the paint job and then the rebuild.
Hoover Constellation Re-build
All the parts are back after a chemical bath, sand blasting and then a new powder coating.
Parts
Blue lower canister.
Light grey upper canister.
The colours are the closest match the coaters could get from the original paint.
First, the base assembles re-riveted.
Rivets from the underside.
Next the motor mount re-fixed.
Base assembly and lower canister bolted together on the hinge.
Clamp fitted; at this point I realized I had forgot to fit the ratings plate on the base.
Next the vacuum chamber assembles re-riveted the bag holder and the wire mesh.
Upper canister, handle refitted along with re-riveting the name plates which are in quite poor condition.
Re fitting rubber seal/bumper strip.
Foot switch
Switch was originally riveted in place; I have used some bolts as I think the new rivets might crack the switch unit.
Motor sitting in the mount, I have not done anything to it as I found it in clean condition.
Terminal block wiring. I have had to fit new flex as the original had perished and was dangerous.
Motor cover/vacuum chamber assembly refitted.
