Hi All,
Just joined the forum. Great and informative. I am located in Melbourne.
I have a Hoover 920 Elite with some spare parts and technical issues which I hope someone may be able to help.
I am replacing the drum seal following a leak under the machine. I have taken the machine apart and have the new seal ready for installation. The problems I have are as follows:
1. The shaft appears to have an indentation all the way around where the old seal was in contact. Is the new seal likely to work if contact is made at the same location on the shaft?
2. I cannot find the replacement "felt" like gasket which sits below the seal. Is it available anywhere?
3. The inside of the shaft just below the splines appears to have seals which I would like to replace. Are these available?
Thanks in advance.
Thanks in advance.
