Hoover Logic 1000 A3670
Cheers Gary.
Think this one needs new bearings as there is a bit of funky sound when spinning, although it's lots quieter than the A3954 I got last month.
This one was made in 1988 - great that it's still going - well made machines indeed.
After having a quick look inside, it feels more 'old school' than the A3954.
Looking forward to getting it cleaned up.
Do you know of anyone who has Hoover Service manuals ?
Any info or tips are much appreciated.
Mike.
Service manual
Got my hands on a service manual.
Apparently it's a B line machine exclusive to Currys.
Door seal and new drive belt are ordered.
Let the fun commence !
The clean up begins ......
White vinegar and cloths at the ready. The big clean up begins.
The A3110 restoration thread on here from last year has been a massive help to me - thanks to all who put this on. This is my first big overhaul.
My plans are:
1. Clean up !!
2. New door seal
3. New tub seal
4. New reservoir assembly - if anyone knows where I can get my hands on one of these I'd be eternally grateful !
5. New brushes.
6. Considering new motor bearings while I have everything apart- any advice appreciated.
7. Hammerite on the bits that need it.
8. Possible new suspension kit - again any advice here would be appreciated.
More posts to follow as work progresses.
Mikey.
rust
Looking good, although I would advise against using Hammerite, as it is not suitable for the job. In some cases, it can trap rust and water, allowing the corrosion to breed.
Use an appropriate rust converter, plus an epoxy mastic paint in black. I use it on my old classic cars (and also on my Hoover Logic with great success) www.rust.co.uk
R
Rust
Thank you for the info.
I was just about to start on the inside of the outer tub and the backplate.
Would you recommend using the fe 123 rust convertor and the epoxy 121 steel renovation paint ? If so, would this be suitable for both the backplate and the inside of the tub ? ( the enamel has worn inside, across the middle of the base of the tub as shown here )
Appreciate any tips.
Thanks in advance,
Mike.
rust
Wire brush as much iron oxide (the brown stuff) from the rusty outer tub as you can, until you are left with as much shiny rust pits as you can. Use the FE123 to convert the remaining iron oxide into a more stable compound. Rust Buster may mix a smaller pot up for you.
Once cured (and left for as long as the instructions state), use the epoxy mastic (http://www.rust.co.uk/epoxy-mastic-rust-proofing-paint/c28117/) to coat over any steel. Being a two pack product, it sets rather than dries and is very, very tough. Use it over the heater mount too, which can rust and break off.
Obviously the FE123 is not suitable for the backplate, because it is not made from steel. On my logic, I used chemical metal to repair holes and, once sanded down, I coated the face inside the machine with black epoxy. No back particles have appeared in subsequent wash loads (and I did loads of oil washes, when the machine was in use), so the paint appears to be staying in place. As always, make sure you are painting clean metal, not limescale/soap scum.
Good luck!
R
Thanks...
... and sorry for hijacking your thread. yes, it is great, no mould inside and in great nick. I replaced the pump and a few perished hoses.
It would make a great machine for someone that wanted an efficient little retro machine. The writing ion the fascia is all intact too.
R
A3888
Yes Mike, I think I will sell it.
It's in my garage and, although it's not in my way, I would rather see it go to someone who would appreciate and use it. I got it from a house clearance - judging by the condition of it, It had not been used much. I think the door seal is original Hoover and is not manky/mouldy at all.
There's no rust/dents either.
I put an anti-twist kit on, a new sump hose and a heater. I used it occasionally as a second machine, and it has been A1.
Basically, a vintage(ish) machine that needs no work, from what I can see.
£60 should be reasonable, considering that is what it owes me. I already have a timeline Logic that I renovated last winter and a Bosch V696 washer-dryer, oh, and that 1509/10 Hotpoint top-loader (and a Bosch WFL2260) so I don't really need another Logic hanging about!
R
