The WM64 is a good machine, especially if it has the later type of motor fitted but it's probably not as sturdy as the 18 series and I don't know if there will be many around in 20 years time. Apart from the usual pumps and brushes, most of the machines like that I went to either had broken drum support spiders or failed door interlocks. When the interlock fails it usually also blows a copper strip on the circuit board but that can be repaired by soldering in a wire link.
