Hotpoint supermatic .One for the UK guys
anthony
May 17, 2011
296
uk
Hi all
This machine is a hotpoint supermatic 9414W with a stuck Agitator .I cant budge the dam thing and i don't want to break anything . When trying to loosen the grey knob it just clicks as its turned .The machine [although its in excellent condition ] hasn't been used for a long time . I suspect the bolt inside the white plastic agitator is seized into the spider underneath . Anyone got any suggestions on how to get some lube in there . Any help would be much appreciated
Heat it up
If the machine is watertight I would get it up to almost a boil and then stick some gloves on and try to see if the screw thread will move .
Managed
to squirt WD through the small holes in the agitator left it overnight and with a bit of fiddling it came loose .No wonder it was stuck probably hasn't been off since the thing was new .it was full of dirt and dried up fluff . The tripod is a little loose so i decided to take it off and see what was going on underneath Managed to pull the tripod off with a set of pulley draws but it is corroded also the seal underneath needs replacing .God only knows where I'm gonna get hold of them
. If anyone has spare ones they want to sell please let me know. My next job is to get the gearbox off and see what's in it if anything hopefully OIL but that's for another day
Tripod
managed to get the replacement tripod from Slowspin so all in need now is a new seal to go underneath it. If anyone has one to sell please let me know .Any tips on getting the [plastic] tub nut off would be appreciated.There is some rust at the bottom of the tub and i would like to do something about it before i reassemble the machine. i have soaked it in WD and left it for a day or two but it wont budge .The whole centre column it turning but the nut wont budge.I have done a lot of cleaning today .the machine is filthy inside and out but under all the muck its in good condition and the white cabinet has no rust .I have also cleaned away all the oil that has leaked from the gearbox due to the plastic plug being loose .Its getting cold now so I'm off back in the house for a hot drink .will do a bit more tomorrow
few more pics
with all the muck removed. So many plastic parts that really should be metal [and once were] the quality went down while the price of this machine went up. The person i got this machine from bought two at the same time ,One for his wife and one for his mum .You can see the variations in price on the receipts that were inside the user manual
They turn up on eBay
The tub nuts are a little tricky to get off but I’ve been able to find a replacement from time to time and therefore cut the old one off . I’ve done this with a hot knife before to prevent damage to the tub enamel . Keep your eye out on eBay . If I see anything I will let you know . Darren
I
only want to take it off to treat the rust before it gets any worse .But i may just try to do that with the post and heater in situ rather than break the nut and not have a replacement but if you come across a nut please let me know .I think the seal that fits under the tripod may be the next big obstacle .I have seen a couple on Ebay but when i try to buy the i just get the out of stock message but i will keep at it you never know one may pop up
Hotpoint supermatic
Another reason the prices vary is due to them being different models the 9404 was a lower end with no automatic rinse feature. and although they may not be as well built they are still around I have 4 all working and in great condition. I have some parts from one a took apart due to not needing yet another :)
yes i realized
they were different models .I wonder why he didn't get 2 the same [maybe Comet only had 1 of each in stock]. I worked on lots of these when i first started work but time marches on and you forget stuff that was once second nature
Hi all
The replacement tripod arrived today [courtesy of Slowspin66] and i have a new plastic nut for the centre post so i did as suggested and cut the old one off with a hot knife . i also removed the heater and the drain outlet . next job was to tackle the rust . I honestly thought the tub was in a bad way but was pleasantly surprised to find that all that rust was caused by some old hair grips and a few nails that had rusted away [ i really do think the agitator hasnt been off for a very long time .even the trap in the tub drain hose was full of crud] . After scraping the rust off and then a good scrub with a brillo pad the tubs looking much better .the only thing i cant shift is the dard stain at the top of the picture .will start reassembly tomorrow
Looks excellent
A lovely job well done . Did you see the top hat seal one forwarded to you from the EBay . That will address the tub issues . Interesting restore
yes
I did see it but i had already managed to get hold of one .Just waiting for it to arrive. It will finish the job off . Can you tell me if i should put a little grease between the tripod bearing and the new seal underneath or is it best left as it is ?
It won’t hurt
Anthony I would put a smear of grease on the drive shaft but not loads as you don’t want it working up the
Support shaft and finding its way into the tub . Pleased you’ve got it going post a few pictures please when it’s all done .
Well i did
a bit more yesterday .Tub is back on although i haven't tightened the plastic nut yet . can you tell me if i have put the drain hose [from tub to pump] back together properly as in the fat bit with the filter onto the tub and the other end onto the pump .I have to say all the rubber parts on this machine are in very good condition [no perished bits any where ] even the spiner drain hose is in good nick however if you look carefully you can see a slight bulge on the black hose in the photo .this was where oil had dripped onto it .Next i put the top on and reconnected all the electrics and the two cables .I also had to move the tension spring on the wash pump as the belt was rubbing against the centre post of the wash tub [maybe a new belt might help ] Will do a bit more tmro if its not too cold
Hi All
this machine is just about finished now .Its all up and running but i would just like to know what the correct belt would be to drive the spin dryer [not the pump] .When i got the machine there was no belt present so after a rummage through my ancient old van stock [or what's left of it] i found an elasticated belt that fits and it works ok but looking at the pulleys on the motor and the clutch pully it looks as though there should be a V belt fitted .
