Gas service in apartments in metro New Orleans
n most areas of metro New Orleans,gas is not allowed to be used in apartments because of fire codes. They don't want to have a leaky pipe under a floor or in a wall in between apartments to cause an explosion. So most apartments are built all electric. Matter of fact,as part of condo conversions some older buildings are actually being converted to-all electric . There is a way around this.
Some larger multi-building complexes have gas on site but it is still not allowed to be piped directly into the apartments.
Gas-fired water heaters and boilers are installed in separate buildings for domestic hot water and heating, as well as the laundry rooms which have commercial gas dryers and their own separate water heaters. Some complexes also had gas grills in the patios for tenants to use and outdoor GAS LIGHTING.But you will always find an electric stove in the kitchen. The only other way one can have gas in an apartment is to have the pipes run externally along the outside of the building and come in through the wall. Most apartment builders didn't like that because it was considered aesthetically unpleasing and costly. They also get a volume discount on electric appliance packages. As a result,only about maybe,say,5% of the buildings actually have gas in the apartment itself.
