Press to Test
Hi Ronan,
The problem we have in this country is that people assume that a GFCI circuit = safety, so these units get installed everywhere. All the while not realizing most units from the box store are of off-shore quality and are of little value to equipment that has a ground conductor. Will they work when you need them (when you end up as part of the circuit)? Will they nuissance trip? Will they catch fire?
To make matters worse, the inexpensive variety are only rated at 15 amps, and they get put on 12ga 20 amp circuits, or slipped into the head of parallel branch outlets. The breaker never gets changed and now the downstream "protection" limit is reduced. Little stickers are provided so that branch outlets can be marked, but that almost never happens.
When it comes to permanent and semi-permanent equipment, a secure ground eliminates any risk of electrical shock while a GFCI can only detect a current imbalance and act accordingly (if it works at all). One need never worry when three Maytags go into spin if they're exceeding the protection limit, or if future protection has been compromised. Plus, one needn't worry about protection being compromised due to a lightning strike or power surge which can affect the semiconductor sensing circuits.
