The combo is a rare machine for sure.
Mixing colors, you are just the typical trouble seeking teenager. Even I never lived that dangerously.
I like your almond belt drive Kenmore. I have to admit with all the machines I have had I have never had a almond Kenmore BELT drive. I've had a top. I have had a almond Whirlpools. I've had Almond Whirlpool/kenmore dryers. Hmmm. I'm a bit envious.
Ah yes, the slight altering of this here or that there. I remember those day. I get the raising of the water level thing. It is easy enough to do by holding the knob between 2 levels or adjusting the set screw.
However, and it has been a while since I have taken one of these apart and I'm sure someone else may know more.
The first thought that comes to mind is that you probably don't want to fill the tub above the heigth of the spin tube. Even though there is, or should be a rubber gasket between the spin tube and agitator shaft. It may leak water down between the spin tube and agitator shaft and cause a number of problems.
Have fun
Um yeah Jason, he got it like a week or so ago from the curb. There is a post on it.
Work, you've been working? Is that supposed to fly as an excuse? Dial-up speed? Ok, that is believable. Well let that slide for you.
