Hypothetical question: Can't 110 volt dryer vents/ fan speed be cut way down?
harpon
Mar 18, 2014
58
Jacksonville
Just musing on designs, because I've been looking at 110 v compact machines, and saw a couple of videos of machines in use.
What struck me tonight is that there's always still a quite active vent with forced air coming out the back. So I started to wonder- How much venting is actually needed? Don't 110 appliances usually draw no more than 1500 watts?
I started wiring up a spare Kenmore space saver in the garage I practically couldn't give away today to 110, after I searched replacement motors on ebay and noticed they were all 110v anyway. I went through this a bit a year or so ago with a small water heater, that I bought with both a 220 element and a 110, and learned that the wattage is cut to a fourth as much using the 110 element and wiring. So anyway, I got the Kenmore to power up the motor, with a 3 prong outlet wired to a standard grounded wall plug. But no heat- and since then discovered that the element has to be wired to 110 separately, which I'll probably do-
because as much as I'd like to get a little 110 compact dryer, I don't want to lay down the $300 right now when I've got a full size 220 already in the garage (I'm eventually hoping to have machines inside the house in the bathroom), AND while I have this already small sized machine that appears may be actually able to be converted. (Pictured below)
So anyway it struck me- if I only draw 1/4 of the 5400 watts of element with 110 volts, then the vent must likely be too large and moving too much air. Wouldn't it be better to cut the venting volume and speed down to 1/4, to retain as much of the little heating wattage the 110 offers?
And I recalled the videos for the new compact 110 volters- it seems there is still a large vent with a really strong vortex. Do you think that is necessary?
There's a youtube link to one below
How hot do these dryers get compared to full sized 220?
They - unfortunately I think- often have a full 20 minutes of cooldown at the end of their cycle- seems like a waste of time and power if unattended.
I'm wondering if I get the Kenmore element wired if I can also cut down the venting- maybe a cover with half the diameter cut out-
How is the air generated? Is it by the rotating drum?
Anybody with any experise or thoughts about dryer venting vs. element power operating temperature, and voltage?
Should we trust the corporate decisions, or will there be a better way?
I used these small WP produced machines for years.   I would not alter the air flow.  They work well enough for the power they consume.  They have a blower just like full sized machines, maybe smaller.  They also have thermostats that measure the heat.  You need the airflow to pull the lint/ moisture to the filter.  This portable design has been in use for decades.  I did forget to clean the lint screen a few times by accident. with no noticeable change in cycle time.  The best tip I can give you is to do your wash loads in the order of what dries faster.  Lightweight fabrics and small loads first.   Dry your jeans and towels in the last loads.  Also wash more frequently so the dryer loads are smaller.  Good Luck.
I've used one since 1984. I wouldn't alter anything. Stopping up vents/ducts makes the dryer take longer, not shorter. This building just had the repairman out because a 240V Maytag wasn't drying. The outside vent was clogged (the maint guy is unbelieveably lazy).
Yes jeans/towels and the like take longer @120V, most everything else finishes in 40min.
Dryer conversion
Harpon, I have read your post twice, and can't be sure of your exact intent. A 220V induction motor will run at much the same speed at 110/120, but with much less torque available, so it may stall, or fail to start completely (and if it does, it will burn out in seconds (be warned)). the blower on most dryers is a fan on the end of the motor shaft, so (if the motor will run at all) airflow will not be much reduced. Strong airflow is good, as previous respondents have commented. The heating elements need to be examined to see whether there multiple elements, series connected, which could be re-wired in parallel (subject to wattage limitations), or whether a 'center-tap' could be connected.
Hope this helps
All best
Dave T
Sorry Dave- you're not getting it. The motor is obviously 110 volt- though I haven't confirmed it yet officially-
and I think a great many, if not most of the motors are 110-
220 is then used only for the heating element.
Plugged into a ground fault 110/120 v plug, it is powering up the unit- both the drum and blower- at normal operating speed-
So I've just been out in the garage taking the dimensions and musing about it-
My Spacesaver is taller, but some of it is more space for older controls, and then several inches deep than the new compact units- a standard 4 inch vent near the bottom of the back- I'm sure it weighs more than the new stuff- but it's here already at least!
since I got the idea yesterday- further internet research has confirmed the obvious- now the heating element itself has to be wired for 110 instead of 220-
with the unfortunate quartering of the wattage- the 5400 watt heating unit will then pull about 1350 watts-
the question now is- how many watts is the motor pulling?
I only have about 150 watts left before the 1500 level that most 110 v appliances are cut at(I'm specifically thinking of my oil filled radiators- which I most often hook to line level individual baseboard thermostats, and are all the heating I need in north florida.)
Obviously the unit should then run on a circuit all by itself- preferably a dedicated circuit, with a ground fault outlet- in a perfect world. It's going to pull about 1500 at least on it's own-
which brings me to my latest musings and speculations- specifically regarding mostly the venting speed, and possibly even the motor speed and power.
I'll probably tinker this still at some level- once the weather and my schedule clear a bit- I'll see then if the ground fault or the breaker then blows, with both the motor and reduced heating element power powered up together- Not expecting trouble though, while it took a couple of attemps to wire the plug to the right terminals on the 3 prong outlet- with some good 10 guage NM line between- the ground fault plug absorbed it well.- I wouldn't want to messing around on old circuits with fuses!
yet the problem remains- a much too powerful blower pushing what little heat the 1350 watts of 110 power will get outta the element- (which would last a lifetime I guess!)
So, without yet having any look inside, and knowing very little-
I'm guessing that the blower is also powered off the same motor-
is the air generated by a blower unit itself or from some kinda fins around the tub?
I've seen one picture that looks like a little blower unit-
is it run off the motor with a belt and a pulley- ??
if that's the case- perhaps a larger pulley and longer belt coiuld slow the airflow down- (I learned this bike riding!)
Another alternative might be to cut the power and speed of the motor- wouldn't cutting the power with a rheostat slow it all down? The element would obviously still need the full juice.
I'm not sure what the physics of the motor might dictate then- would the motor have the power to turn it all slower? Or would it stress it? Please don't naysay if you don't really know!
I think it would be great if both the speed of the blower and the speed of the drum were reduced- and it would definitely be a quieter unit-
but what is the more important at this point is simply slowing down the blower and the rate of the discharge of air only heated a quarter as much. Reducing the outlet would only collect more lint- but perhaps not at 220 volt levels.
I'm also wondering about LINT- What causes it? Is it more influenced by temperature or by the speed of the tumbling?
The lint is supposed to be trapped before venting, but the vent obviously has to be cleaned out- because of lint in the vent air and I see pictures of people venting UP? Doesn't that make less sense? (see middle photo in ad link below)
Is there a LINT expert in the house?
Is there any reduction in lint at lower temperatures or lower tumbling speeds?
http://www.ebay.com/itm/Sonya-Porta...300932733125?pt=US_Dryers&hash=item4610fd18c5
Ooooooh. INSPIRATION!
Another idea!
What if I can simply SHROUD the blower unit itself?
That won't itself result in any more lint buildup in the vent pipe I think- it would only reduce the airflow and allow the temps to increase in the unit as it operates-
This may make the idea more viable!
Okay looking at this all some more-
I've been perusing replacement motors on ebay- all 110- 120 volt and all seem to run at 1725 rpms- 5.5 amps is thrown out there a lot-
not sure how that relates to watts and how much wattage the motor pulls
below is a link to a motor and blower overhaul kit-
So it's obvious that probably some variance between the motor speed and blower velocity could be achieved with pully sizes and varying belt- may be difficult in practice- not sure at this point-
looks like the motors have shafts on both sides-
one for tub, one for blower ? I guess.
Also some altering of the blower fins could obviously cut the velocity as well-
still think the shrouding or partial diversion of blower stream may be the most practical and easily accomplished-
The tub isn't as much an issue because the spin drying isn't bad-
A lot of people say that cutting the wattage of the heating element 1/4 increases the drying time by 4- that doesn't make sense, because the spin dry aids drying even without heat- but certainly makes it all longer.
but what I'm interested here is maintaining more the reduced heat
I would still personally favor any machines designed to rotate slower and vent the lesser 110 heat not so quickly- but that's just me- I'm the same way with AC units-
Give me a slower blower whose noise doesn't drive me crazy all by itself!
http://www.ebay.com/itm/COMBO5-Drye...825?pt=LH_DefaultDomain_0&hash=item2336947af1
Had some dinner and looking at this further-
So I see this motor (link below) and the blower wheel with fins is attached directly to the motor, and shrouded by a plastic assembly that directs the air-
So then if this is typical, there's little chance of "changing gears" or any pulley sizes to make the blower velocity less intense- bummer-
but it may be easy to baffle that- or make changes to the shroud to reduce velocity
It also maybe already answers a question I was forming-
Apparently their are already models in cases that look much like mine- Kenmore and I think I've seen Whirlpool- that come from the manufactures already wired as 110/120 volts-
so I was wondering- in the 110 models already out there for years-
1. Is there a different type of heating element?
And
2. Has any alteration been done concerning the vent velocity, to compensate for lower heat?
Knowing the corporate landscape, and obbsessions with the QUANTITIES of production, I'd be willing to bet that the answer to the second question at least is "no", and that the same motor and shrouds and blower fins are used whether the unit is sold as 220 volts or as 110-
Unfortunate-
and I'd be happy if someone with insider knowledge who knows for sure tells me differently.
Anyway- I've wasted enough time on it today- but enjoyed mulling it over-
if I get into the case- I'll report here what I find
http://www.ebay.com/itm/GE-Dryer-Mo...d=5608030963563493549&pid=100005&prg=9373&rk%
motor
"split phase"motors as used in American dryers are not practicle to slow down because the centrifugal switch will not switch off the start winding and it will get hot.To reduce airflow through dryer,restricting the vent flow is the only easy way but could impair dryer performance by reducing the discharge of humid air from the drum and create an overheating hazard if restricted too much.
OK- good that tells me something- Thank you
I've been watching videos about it all on youtube
I think the way to go at this point may be just to get it running on 110 and see how it goes-
cutting down on the airflow would probably be practical, but I'm wondering if it's worth the risk-
I'm just speculating that with 11o power to the heating element- I don't think the upper temp cut-off thermostat would ever reach cut off temp-
I suppose the ultimate tinkering would be to find at what air flow restriction level that started to happen- and then backing off from that point.
I'm just amazed now that the blower is actually more "sucking" the air through the system and actually most near the outlet end of the line
Reducing the airflow for a 120 volt dryer?
Yes you could do this, BUT it will make the dryer use more energy, take longer to dry and likley cause problems with clogged vent systems.
You correctly figured out the a 240 volt dryer operated on 120 volts only produces 1/4 the heat, but the interesting thing is it usually only takes three times as long to dry a load NOT four times as long and the other end result is that you actually save about 15% total electrical consumption. This is because of the higher airflow compared to heat input.
The only reason to restrict the airflow was if you were very concerned about the amount of heated or cooled air you were sucking out of your home, and if this is an important factor for you you should locate the dryer on the porch or in the garage anyway.
Do note, there is no such thing as a 110 or 220 volt dryer, check the model# tag or the specs on the motor, heating element Etc of the dryers you are talking about. If you are using the wrong voltages in your calculations it makes you look very poorly informed.
I'm just using common terms 110 for 110/120 Volt and 220 for 220/240 volt I guess- I think the names have changed through the years-
the difference being whether one or two 110/120 volts wires are hooked to something
I see them advertised on craigslist and ebay as 110v. I guess they are more officially 120v these days-
I don't think a smaller airflow with a lower heat 110 machine or wiring will necessarily clog more- but a crude baffle might-
I'm just saying that with less heat going on in the dryer,
the venting probably theoretically doesn't have to be the same-
I'm still wondering about "LINT"-
Does it occur less in lower heat? Is it more a product of airflow and tumbling?
I'm just guessing the heat factor means more- but just guessing.
Anyone familiar with the "science of lint"?
Below is a video I found that's very comprehensive about the basic principles- and also demonstartes how the 110v motors are wired into the 220 circuit, and only the greater voltage used in the heating elements.
What I'd like to compare someday are the ducts and blowers and heating elements inside my own Space Saver machine- wired and sold as 240 v, with those units that look the same in every way and sold as 110.
Is ANYTHING different about them? I wouldn't be surprised if they have the same ducts, blower and even heating elements- I'm not talking about their wiring-
if they have the same blowers and the same ducts- it just seems to me that they could be made more efficient by retaining more heat with less air flow.
all I'm sayin....
OK-
I'm not going to keep running all this into the ground- but may dredge it up as I tinker more.
Below is a link to the best discussion on LINT I could find on the net-
(I've only more got the feeling that the manufacturers are sort of avoiding the issue as it relates to this discussion of air flow and lower temps of 120 v power- and i suspect that's because the U.S. manufacturers at least may be not compensating for lesser power at all, in machines that are basically the same size and weught and with the same motor as the 240v models, and still just as heavy- I've come to feel that much of it revolves always to the end of selling lots of gasoline, but that's another weighty issue and discussion)
Anyway- as much as I'd like to get a newer asian 110 unit- and they are putting out a model that more like 21-22 inches deep instead of 16 or 17- I'm still enthused that the Space Saver I already have- and couldn't sell for even $40 last summer- actually has more space inside it's much heavier frame. So it's got some potential for 120 wiring- I may eventually convert the plug itself instaed of jumping it with the 3 prong to wall plug homemade rig-
Some of my thinking started more leaning to 110 volts when last month my other dryer melted the 240 outlet and almost set the garage stud on fire- I was fortunately right there as it started to blaze-
and I have to take some responsibility- I had heard some arcing on start-up- that I didn't realize realize could grow into such a problem- I first thought that perhaps a lizard had crawled inside the conduit and gotten fried- but a lesson to learn for sure- If you hear arcing from a high powered plug especially- don't keep running it!
I've replaced the fried plug and it's run a few loads since, but all this as I'm making plans and working to have machines in my bathroom inside the house and not the unattached garage- so I'm more fire-hazard conscious now-
Plastic DOES eventally start to burn!
Anyway- I'm stll thinking that lint may not even be such a problem at lower heat of 120 volts-
http://www.laundrytoday.com/index.php/business-mainmenu-29/lint/312-what-causes-lint
Done some research now-
here's my macine basically, the same cabinet ans size I think but sold as a 110/120v unit- it is 3.4 cubic feet otherwise- so larger than the asian units but much more expensive new- used ones ARE out there quite a bit I think, for much less- I paid $75 for this one two years back, and have seen them as low as $25 on craigslist
The link below is to the customer reviews- and the lowest rating from reviews seems to address this very issue- the most common complaint is low heat and extended drying time-
I'm just guessing that the blower and venting is the same as with my 220 v model- but hope I'm wrong. If it is though- it's just a bit stupid and could be easily adjusted to retain more heat-
There are also some specs listed here, and the 15 amp circuit is described as minimal- so I'm going to search around and see if I can ascertain whether there is indeed a different element or motor used. I'll bet the motor at least is the very same.
http://www.sears.com/kenmore-3.4-cu...p-02684722000P?prdNo=1&blockNo=1&blockType=G1
I've got 120v HEAT going now!
It's still just jumped with my own 3 prong female to two prong 120 adapter- so I'm going to change the whole cord out when I get a suitable replacement- though I have lots of fresh NM 12g wire I could just wire to a plug- so that may happen- i think it would be nicer to have a normal looking heavy line
Yes, you have to jump the neutral central to the old second RED 240 terminal to close the 120 circuit on the heater coil-
And so I was a bit wrong on the coil- apparently they DO change the coil between a 120 v unit and a 240- generally going from 5 coils down to 3 in the 110.-
Yet I seemed to be getting some good solid heat off the 240 coil on 120, so I'm not planning to change t for now-
but I still think the blower fan and chamber are the same whether the model is sold for 120 or 240-
My idea now- if I find the unit not heating as much as I'd like- is to perhaps get another blower fan wheel, and at my convenience- simply drill some holes in some or all of the fans- that would surely cut the air velocity- and I could start gradually and do more later- depending on what kind of a job it may be- I haven't even opened up the blower housing at this point-
But I have noticed one thing- there seems to be ONLY ONE blower fan listed as a replacement- NOT a separate one for 240 and 120v models-
so that might be a corporate decision based on production levels that may be able to be tweaked easily to get more heat retention in the unit on 120 power-
there's also a HOLE manufactured into the top of the heating element duct, so that in fact all the heat is NOT being diverted through the tub, but being vented into the unit in general, and even may be raising the operating temp of the motor itself.
I may drive a piece of pie pan aluminum over it with some sheet metal screws.
anyawy- VERY ENTHUSED NOW! and glad I didn't yet balk for the asian unit
This is GREAT- I'm sure glad I couldn't sell it before.
I'm going to take some photos of it all sooon, so stay TUNED!
That hole at top of the element box has been the case for *years*.  I've posed the question a couple times of why is it there and no one has answered so it remains a mystery.
When GE offered instructions for their full size dryers that were operated on 120 volts, they offered an air restrictor plate that was placed where the lint screen went, after the screen was removed, for drying Wash 'n Wear loads. The lint screen was not really needed since the fabrics did not give off much lint anyway. The air restrictor enabled the dryer to reach proper dewrinkling temperatures, 160F, for best no-wrinkle drying. It was the only type of load for which the temperature was important, but I have successfully dried perma press garments in 110 volt dryers and had them come out with no ironing, so the quest for higher temperatures in your compact dryer would not seem to be very important. If you let the dryer run past the point where the load is dry, the temperature will rise quite a bit for dewrinkling. I suppose you could paint the cabinet black and place it in the sun and run it or you could use it in the garage where it would be warmer and that would give slightly higher drying temps.
It's as much in my mind at least that it's just blowing the lesser heat right out of it- it's costing power and that costs me time and money.
If it were taxes being spent- people would hang for it- but it's just coprporations eating up your own income by not making an adjustment over something- choosing the easy way to put out something in both voltages without adjusting the parameters- and throwing the same parts into everything-
You'll just have to labor more to pay a bigger utility bill- climate concerns not withstanding. The drying time should not be solely dependent on the wattge of the coil- Whirlpool/ Kenmore has taken the easy way out by using the same set-up other than the coils, and the machines weigh a lot by more modern standards and so they still have greater transportation and shipping concerns.
TYPICALLY- as I've looked at heating elements- the ones specified for 120 volts are much more EXPENSIVE than the 240 volt wires- when they have less wire and coils in them- and generally on the same frames of their respective eras. The ducts and blowers are the same for both 120 and 240 volts.
I've got the machine wired now with a normal 120 volt plug, So I'm all set to try some clothes in it when I wash some- for now I've covered the hole at the top of the elewment vent with a simple piece of duct tape- but not sure it will last long.
I've tried to date the machine but got inconclusive results- I think it was made about 1978-80. It really wasn't very dirty inside- so had either been cleaned along the way, or used little.
I also thought of putting more screen mesh into the lint filter to decrease airflow sucked through by the blower, and that's another fairly easy thing to do-
For now I just need to see how it goes. I'm tinkered out for awhile now at least and just need to test it. I'm wondering how I could get some kind of temp reading inside the drum.
Sorry- no pictures yet- I was too busy working out the bugs, including taking the back cover off again unnecessarily one last time, when the dryer timer had simply reached cooldown and I was then puzzling as to why it wasn't getting hot - I knew I was punch drunk by then!
Below- these units are getting wider now- and the cubic feet is actually more than my Kenmore now- and at half the weight- I have to wonder....
These larger asian units claim a weight of 44 lbs- while the Kenmore is an entire 100 lbs- How do they do it?
anyone have one of these? Are they strong enough? I doubt they vent as much air, but just guessing- the Space Saver really blows it out the drum!
Your idea of putting screen mesh on the blower is quite crazy- it will also make another lint trap for the lint that doesn't get stuck on the first one, so that should be avoided. Lower heat will not produce less lint- no matter what temperature it is set on it will still produce about the same amount of lint.
A 110 volt dryer won't produce as much heat as a 230 volt one due to less electrical friction in the element.
Less heat might make the dry time longer, but it will cause the clothes to last longer, due to the more gentle heat, so I HIGHLY advise against restricting the airflow to produce more heat.
Your dryer should be fine the way it is and again, I HIGHLY disapprove restricting the airflow. If the airflow is restricted, you'll also cause the high limit thermostat to constantly to kick out and it will break, and it will make another lint trap for lint to get caught in. On those dryers, the fan is directly connected to the motor and the drum belt is also connected, too. I f you use a rheostat to control the speed, the drum will tumble very slowly, and the motor will be very weak. If the speed is slow enough, the motor will stay in the start winding and it will overheat and blow up. The heater is connected to the centifugal switch on the motor and the drum will not heat, so you shouldn't use a rheostat to control its speed.
I hope this helps.
The extra screen idea is for the lint filter, not the blower-
and I disagree with most of your post- and I think less heat will at least DISLODGE less lint, if not make less of it. Heat will get it more airborn, so lets see if we can get some to FLY!
Anyway I just finished a load- a smaller laundty basket full- the unit is 3.4 square feet- of about 8 pair cotton underwear, two tee shirts, a top sheet, two light towels and five pairs of socks-
ONE HOUR dried it almost completely- the towels were slightly damp, the tee shirts just the slightest trace of damp, and all else dry.
I periodically opened the door to check the temp-
yes, yes 120v heat- probably NEVER GETTING NEAR thermal temp cut-off-
So I'm satisfied covering the little hole at the top of the heater element duct with duct tape is no problem- and I'll probably drive some pie plate alumuniinum with two screws over it permanently-
and I'll eventually decrease the airflow- the motor speed was just another idea earlier, and I'm not going to play with that-
but less airflow only makes sense, and I have another idea for that- perhaps some drillings in the blower housing itself-
and here is why- when I began this thread I was under the impression that the blower BLEW air through the system-
while now I see NO-
it really only sucks air out of the drum!
The blower is at the END of the endflow and only pushes it out of the vent it lies inches from. Then I was thinking the blower sucks the air through the whole system- and this it may do a slight bit-
but the drum is NOT airtight- it really seems to be only exhausting the drum- the heater coil is on the other side of the back- and its' duct goes up and into the drum-
The hot air heated will RISE and go into the drum whether the blower has influence or not- also the tumbling clothes will create a vacuum by their very movement-
so now I believe that the blower will not affect the level of heat into the drum- only the RATE at which it exits-
so the drum is geting warm now- but not HOT and the clothes are drying-
but they CAN dry faster
and incidentally- I didn't use any venting out of the machine- I opened the bathroom window and turned on the overhead bathroom vent, and closed the door-
north Florida temp approx 65- 70 degrees- and I had no problems with excessive heat or lint.
An hour's worth of drying- VERY MODERATE thin lint coat over lint screen-
it only confirms my own belief- there's less lint here than my other 240 volt, though it's larger
no I may not put mesh there- but may try because it's so easy-
but if I really want to reduce the airflow I'll drill holes in the blower fins, or the blower housing-
the fin idea would draw less lint into the outer housing- but either will cut velocity and keep the blower from sucking the low heat out so fast.
it's a olong long way to cut-off temp on 120 v
and I'm already at 1 hour drying time- if I can cut that to 45 I'd be very happy and only about 15 minutes more than my larger dryer on 240-
so on we go.....
The blower pulls air through the element housing to heat it, through the drum to extract moisture from the tumbling clothes, through the filter, then blows it out the exhaust.  Relying only on convection currents of heated air rising in the element housing into the drum is likely not going to work very well ... the blower needs to actively pull air through the element.
Too much reduction on airflow cuts the rate at which moisture exits the drum and tumbling clothes. The drying process is not only about the heating, it's also very much about the airflow.  Full-240v dryers with clogged exhaust ducting get hot but drying speed is (severely) reduced due to the impact on (not) moving the moisture out.
Heat does not cause lint.  Lint is from the physical abrasion of the fabric during tumbling.  The only reason for a filter in the dryer is to catch majority of the lint before it gets into and clogs the exhaust ducting ... or accumulates into an unsightly mess on the ground outside the house at the exhaust hood.  The airflow pulls the lint particles out of and off of the clothes (so they're not left linty), but it does not *cause* the lint.
Alright- I respect your view but I'm still not sure if its right-
as I said above- the drum isn't airtight- I have a lot of doubt about how much air is actually pulled past the coil by the dryer blower at the other end of the exhaust vent- then there is also that HOLE at the top of the heating element duct-
below is a picture- not mine I got from another thread- but the configuration is exactly the same as mine- only my hole at the top of the heater duct on the right is not that large or round. I was sticking y finger in there when I'd first turn it on while rewiring to see if the coils were heating- I felt no particular strong airflow, nor excessive heat, and the hole itself would prevent a lot of vaccum effect past it- so I think the coil heat IS actually largely convection. I taped over the hole and will seal permanantly it just to not let insufficient heat escape there.
I was toying with an idea about turbo-charging the system by running some of the final vent back into the heating duct, and the nice round hole in this unit looks enticing to run a tube into,
plus it wouldn't pass the coil that way- but I nixed that with respect to it being MOIST air and needing some escape- the small 120 v heat blowing SO HARD out the back is still another matter.
Incidentally I ordered another heating coil, as this one proved not even labled to be the 5400 I thought- 3700 or something I think it said before I stuck it back in.
So, yes, I think your airflow concerns are more paramount in my concerns as well- but it just still seems an excessive vent with such little heat, and then there's the fact that the same blower and ducts are used in the 240 models. So in short I don't see the blower sucking air past the tumbling clothes. I see the tumbling clothes getting air by tumbling and through the heat duct opening and around the drum edges, but the air is only being vented out, not sucked through the heating duct.
I may take a pie plate cover the vent, worm clamp the wrap-
but cut the bottom third off- so lint can still escape
and try that- I MAY someday- just to experiment- better still as far as i'm concerned would be to reduce the fin volume- filing, grinding , breaking, but probably best drilled here and there, to reduce the blast out of the vent- if it didn't work, just put another in- Probabaly more viable than the duct cover, but harder and more exspense to reverse. May even take some strain off the old motor by not constantly pushing so much air.
You may be right about the lint and probably are- but an hour's worth of drying at very low heat didn't produce a healthy "peel" off the filters- I had to scrape the small amount-
so at this point I don't see it as much of a problem beyond routine maintenance, and if I reduce the airflow sometime in the future- I will at least get a good feel for what the norm is now- then I can more have a feel for what's what by trial and error and not speculation
In fact blocking the end vent may not have a good effect- while the heat so far is far from dangerous
and the lint level nil-
it would create a blow back and still the blades would catch as much air resistence-
I'll probably reduce the fins in some way-
that simply will lower the exhaust velocity-
time will tell- I don;t plan to do this soon
but now I'm simply intrigued by the question
http://www.ebay.com/itm/KENMORE-DRY...337?pt=LH_DefaultDomain_0&hash=item20e07410d1
NOW after watching a couple of videos about replacing the blower wheel-
I'm doubting that I'll do anything to the fins- or at least NOT with a new blower wheel-
because the replacement involves taking the dryer completely aprt- from both sides- the drum out belt off- turning nuts on the motor shaft with SAE wrenches I don't have, removing the back cover, etc, etc etc.
in short- beyond me and beyond a level of involvement I want- I could still file the fins down a bit- and that wouldn't be too hard- but virtually irreversible without replacing the fan- if it broke, I'm screwed
too bad- replacing the fan is ridiculously difficult, even for a bicycle mechanic of days past.
I may try the pie plate idea on the vent- but if it doesn't work well that's that.
Hey what about MORE COIL on another separate line further up the element vent?
sorta joking-
mount a benz-o-matic in the back and sticking into that top vent hole?
below- one of my more practical t inker toys......
I rethought of the other idea I had earlier and forgot:
possible drillings in the blower duct above the blower- they could be screened maybe
or even slightly spacing the duct away from the body with something- leaving a sliver of air leak-
THESE solutions would be easy to do and fairly easy to reverse I think- especially any spacing solution-
any way, the blower would be drawing in neutral air from the dryer case and with less force out of the drum- letting more heat build up, but still having plenty of escape-
If you think about it, the constant between the 120 and 240 volt models is the blower and duct set-up,
and the drum speed and tumbling are the same,
the variable is the heat put in- a full 1/4 less the wattage at half the voltage
So the drying time is extended- with a plus that no exterior venting is easier to achieve if it's not a scorching Florida summer day-
But why is the time extended? Because there's less heat. So the heat needs a chance to build up to the more "normal" operating temp-
aby small cuts in the air flow shouldn't make that much of a difference, because the moisture is leaving the clothes more slowly-
So I personally think there's a margin to work with- the heat will never build up to 240volt levels anyway - so a gentler air flow should handle lesser temps curving up on a graph to a point where the loss of air flow becomes too great to remove the moist air- I thnk it's some ways out there on the graph, and the drying time can obviously be cut with no real safety issues-
If I were to design a dryer- I think I'd put the 120 volt heating coils under a drum that had slots in it to fan it upwards,and surrounded by a light aluminum shroud to keep it there, except I'd then vent it out the top, with possibly a small fan motor attached to a thermostat like the one on your car's radiator
below-
outside airflow on the blower duct (removed here) on the left could be introduced to reduce air from the drum without altering the blower,
but that is a HUGE opening for the lint filter in a smaller drum and using much lower heat
You are wrong in your thinking about airflow. Proper airflow is essential to proper dryer operation and safety. That's why the hi limit thermostat is on the heater box. Improper airflow and it gets too hot in the heater box and the hi limit will cycle the heat off. Most modern dryers also have a thermal cutoff on the heater box which is a last line of defense safety device to cut the heat of permanently (non-resettable device).
From Whirlpool training manual:
Reduced air pressure in the drum during operation
draws the seals in and effectively seals the drum ends.
The two seals, one at the back and one at the front,
are the points most susceptible to leaking. If either
does not seal effectively while the drum is rotating,
there would not be enough air passing through the
heater box.
If air is allowed to leak in through any point other
than the heat source, drying efficiency is greatly
affected. Not only is the lack of heated air a factor,
but it must also be remembered that the heater is
generating a predetermined amount of heat. If not
enough air is passing to carry off the heat as fast as
it is being produced, the excessive temperature
building up in the heat duct will open a hightemperature-
limiting safety thermostat switch and
shut off the heat source.
From GE service manuals:
Let's talk simple terms...
Imagine the bathroom it the dryer, the heater the dryer's element, and the exhaust fan the exhaust blower, the steam is the moist air generated from the clothes. It is a cold morning while you want to take a shower, to your idea is like taking packing tape and covering half of the heater's inlet vent to make the air coming out hotter. You also use the tape to cover half the exhaust fan's inlet vent so the heat won't get blown out of the bathroom. You turn on the exh. fan and take a hot, steamy shower. While you are taking the shower, the steam builds up in the bathroom. Since half of the airflow is restricted, it takes twice much time to exhaust the steam. Also, the heated air coming out of the heater is hotter, but it takes longer to get it around the room because the air is coming out at half of the speed.
So, in the dryer, it will impede performance, because it takes longer to get the moist air out of the drum, and longer to get the whole drum heated up.
***Also, the dryer WILL NOT get hotter, due to the cycling thermostat cutting the heater off at the right temperature.***
TRUST ME, you will regret doing this.
