harpon
Just musing on designs, because I've been looking at 110 v compact machines, and saw a couple of videos of machines in use.
What struck me tonight is that there's always still a quite active vent with forced air coming out the back. So I started to wonder- How much venting is actually needed? Don't 110 appliances usually draw no more than 1500 watts?
I started wiring up a spare Kenmore space saver in the garage I practically couldn't give away today to 110, after I searched replacement motors on ebay and noticed they were all 110v anyway. I went through this a bit a year or so ago with a small water heater, that I bought with both a 220 element and a 110, and learned that the wattage is cut to a fourth as much using the 110 element and wiring. So anyway, I got the Kenmore to power up the motor, with a 3 prong outlet wired to a standard grounded wall plug. But no heat- and since then discovered that the element has to be wired to 110 separately, which I'll probably do-
because as much as I'd like to get a little 110 compact dryer, I don't want to lay down the $300 right now when I've got a full size 220 already in the garage (I'm eventually hoping to have machines inside the house in the bathroom), AND while I have this already small sized machine that appears may be actually able to be converted. (Pictured below)
So anyway it struck me- if I only draw 1/4 of the 5400 watts of element with 110 volts, then the vent must likely be too large and moving too much air. Wouldn't it be better to cut the venting volume and speed down to 1/4, to retain as much of the little heating wattage the 110 offers?
And I recalled the videos for the new compact 110 volters- it seems there is still a large vent with a really strong vortex. Do you think that is necessary?
There's a youtube link to one below
How hot do these dryers get compared to full sized 220?
They - unfortunately I think- often have a full 20 minutes of cooldown at the end of their cycle- seems like a waste of time and power if unattended.
I'm wondering if I get the Kenmore element wired if I can also cut down the venting- maybe a cover with half the diameter cut out-
How is the air generated? Is it by the rotating drum?
Anybody with any experise or thoughts about dryer venting vs. element power operating temperature, and voltage?
Should we trust the corporate decisions, or will there be a better way?
