sudsmaster
To commemorate my recent acquisition of two vintage Miele washers/driers (W1065/T1050/W1918) I finally broke down and ought a big box of Persil at my local Miele dealer. It wasn't cheap: $59 for a 12 lb box. That's a bit more than the $41 for same size box I was quoted at same store about five years ago. Works out to abour $1/load.
Ran a first load with it in the Neptune 7500. Bath sheets at hottest (130F) temp. First added 1 oz, little sudsing. Added about another 1 oz., noticed some sudsing, which did not seem to increase as the temp went up. Left a light foam in the boot at end of cycle, even with 4 rinses. So did an extra rinse/spin. Dryer yielded relatively soft and fluffy results w/o fabric softener, not quite as soft as when I use Safeway Select Free and Clear liquid, but close. Definitely softer than when using Sears Ultra Plus HE.
I will probably be using the the Persil in the Mieles, mainly. Will run a load of whites with it in the Neptune to see how it does. Definitely want to see how it performs in the W1065 at 200F, lol...
I notice the ingredient listing is more complete than with most American detergents. Thanks, EU! As Launderess has noted before, it lists soap as one of the minor ingredients. I imagine this may help to supress foaming, but not entirely sure. It might also help with a soft final result. I am thinking I might try adding a little grated/granual Ivory bar soap to my regular Sears HE powder/STPP mix to see if that helps to supress sudsing and give a softer final result.
The fragrance is a bit strong, but not objectionable. Sort of a piney-lemony scent (is that lemon verbena?).
http://scienceinthebox.com/en_UK/glossary/builders_en.html
