there are a few things that the electronics do that a regular timer wont....
if set to HeavyDuty for example....wash speed will only be HIGH if the water level is set above half....lower levels default to lower agitation speeds for better fabric care...
neutral drain periods are matched to the size of load, smaller loads don't require the full 4 minutes for pumpout…
during the PermPress cycle, bleach dispenser is not activated, as thought that bleach would not be used during this cycle....I think they may have changed this as people would pour bleach in during one of these loads, it would not be dispensed, and then on the next load of a Cotton Sturdy cycle, it would...and people would complain that it poured bleach over a colored load....all the more reason to pay attention to the owners manual... as you know, people would not dare blame themselves...
top part of the console will lift to change the bulb or for more usage instructions...
one feature the 1988-89 dryers had was a 'toss to the front' option....it helped unload clothes from the rear of the drum...
