Good to see you here again Drew. Healing takes time. As the Beatles said, "Whatever gets you though the night."
The original Stop & Dry Norges were roller driven and the lever to stop the tumbling just raised the drum off the drive roller. It had a rectangular spring-loaded bar or rack. If you positioned the drum so that two vanes were at the 10 o'clock and 2 o'clock positions, the rack could be squeezed to make it shorter and placed between the two vanes and allowed to return to its original length where it would stay. Things could be hung from the rack to dry. If two vanes were at the 4 and 8 position the rack would sit on them and things could be placed on the rack to dry. I notice the huge fan behind the drum. Norge used to talk about the 21" diameter fan being the largest in the industry, which it was, but it was not as efficient as a squirrel-cage blower so a smaller squirrel-cage blower could move as much air.
If the large coil is only broken in one place, you can stretch it, make a loop at either end and use a nut and bolt to join the two sections. It's not ideal, but it would work for a while. The Her Majesty had a type of soft heat called Velvet Heat. It ran on high heat (both elements or high gas input) until a set temp was reached. After that, it ran on the lower heat input. It was not as fast as Soft Heat. I think Wards dryers had auto dry before Norge offered the feature on their machines.
I loved the power-washing a metal barn simile.
