I got a Westinghouse dryer
Great looking dryer
They do run hot, and with a new belt, run very quietly. One downside is that they tend to go through thermostats faster then other makes. My mom had a 1956, and dried a lot of our stuff on low heat. since yours does not have that option, I would watch the time that you set it for, until you get used to it. Beware of sheets, and Jeans, as they can scald your hands if you are not careful. Congratulations on scoring a real beauty.
Hugs
David
I guess I am kind of used to hot dryers
As both the The Miele and GE dryers Get their rated load done in about 40 minutes, although I’m expecting it to take a bit longer due to both of those driers being about 13 amps at 240V, although the Miele Can change in between 10 and 13 A
Early WH Slant Front Dryer
Hi Adam, What is the Amp draw of this dryer, it may not have as large an element as the US versions ?
This dryer uses 2 V belts they should be easy to find IF needed, I would take it apart and look first the belts might be the least of possible things that are needed.
John L.
Don’t worry I’ll let you guys know, although the seller
Says that they have not tested it, but I’m sure it’ll be somewhat simple and Yeah, I know that you guys have a weird 240 V system And the most I’ve seen our dryers draw is about 13 amps, Occasionally you get a dryer that says it takes up 20 amps Nothing really compare to your American dryers
