I got the Maytag A23CM, but it has issues
smartdrive1100
Feb 15, 2022
162
Melbourne, Victoria, Australia
The seller said that the drum locked up and wouldn’t spin, so he got the repairman to have a look at it but the repairman clearly never worked on a Maytag(also managed to ruin the tub ring clamp, but it might be ok I haven’t had a good look at it yet). He thought the tub bearing was the issue but I never have heard of a Maytags drum locking up because of the bearing, I’ve only ever heard of a Maytag locking up because of the brake not releasing.
Anyway, I has looking to see if anyone had a cheap nut and wrench so I could replace the broken one.
Oh and I did get the LAT9800.
Bad Top Spin Bearing
Hi, These can and do lock up if moisture gets in long enough and then the washer sits for a while.
The repair guy did not hurt anything, you have to break that corroded lock ring off anyway and a new one comes in the repair kit.
It also looks like the agitator shaft is likely in bad shape so you will need a transmission or a new transmission top and rebuild the rest as well.
I have never seen a MT brake lock up, it just does not happen, about the only way it might happen is if the machine sits in a foot of water for severals years but if that happens you will have greater problems that a bad brake.
John L.
Thought the brakes have locked up, I’ve heard people say that, maybe I just misunderstood what they were saying
Is it the transmission bearing or tub bearing?
I’m thinking of doing a not so refined repair on this machine, wonder if I could put some oil on the bearing to see if it will free up? Then just put a spare nut on? If so, what oil should I use? Just some WD-40? Just kidding.
I’ll try and refurbish the top of the transmission the best I can, I have the LAT 9800 that I could look at for reference, I’d assume they would look the same when the agitator is removed.
If the bearing is leaking (don’t think it is), I might replace it.
The machine overall in not the best shape, I will just wait until another pitman Maytag comes up and get that and make a working one out of the 2.
Turns out the transmission has been leaking oil, is there an easy way to fix it? Or is the transmission stuffed? I know that in the later models they had a replaceable seal but on my machine I don’t think it has one.
The tub also has a hole about 1 1/2 cm big any way to fix that?
I find the machine very interesting as the way it selects a cycle is very similar to an a900-906
