I won something on Ebay
Styli, phonolube and rubber rev on order
Just ordered extra styli, phono lube and rubber revitalizer so once that comes in, I'll pull the turntable, give it a going over and Maggie will be ready to wash 'n' roll. YAY for vintage record players.
It is a good idea to remove as much old lubricant as possible using a solvent such as isopropyl alcohol before re-lubricating. If the speed sounds slow the motor may need to be disassembled, cleaned, and the bearings relubricated with a light oil.
If rubber rejuvinator doesn't help the drive wheel another trick is to mount it in a drill chuck and gently grind it against some sandpaper attached to the workbench. This will help renew some traction.
