IFA 2019
Yes, the manual and the press release both state that the 59-minute cycle is rated for up to 5 kg - which is on par with similar cycles by other brands.
From what I have seen on YouTube, a large load will increase the cycle time on the Q-Drive models as the backplate action is reduced. A full 9kg load at 60C resulted in a cycle time of 2:03 hrs in this Samsung washer.
Thank you for that donprohel - European appliance brands will be even stronger EU commission haters after that...how much wasted R&D effort, and how big a swing will happen back towards traditional units now? Man, they messed that one up so badly.
The biggest problem with the Dyson handhelds is that as each generation becomes larger and heavier, they become more cumbersome to use.
DC59: 4.6 lbs
V6: 4.9 lbs
V7: 5.45 lbs
V8: 5.63 lbs
V10: 5.9 lbs
V11: 6.68 lbs
Sure the V11 can for most folks replace their plug-in vacuum... but what replaces the compact and lightweight handheld that the Dyson itself once was?
Well,
as cars got better, they also get a bit larger, or at least used to. I dunno what I'd expect a company to do, other than improve a design, and run out it's planned obsolecense life of a decade or so before debuting an altogether new model, though they tout each new facelift as "all new". Most things have been done before.
I uesd to say a car was all new when the undercarriage frame, or platform, and suspension parts were totally different from the previous generations. This usd to occur about every 5 to 7 years, when we were a more throw away society, and sales were much higher.
>> Well, as cars got better, they also get a bit larger, or at least used to.
The difference, of course, being that people don't routinely climb into vacuum cleaners, nor do they carry cars around with their arms. :D
great selection of machines at this year's IFA, I quite like the new Vestel models with the fun to watch JetSystem, as well as more Hoover/Candy models getting a Bianca-style scrolling-text display across the range too, the new Bosch/Siemens models with the JetSystem looks good and I look forward to seeing 1 in action too, I also noticed that the Serie 2 models are being updated as well using the WAE/WAN design. Not a bad selection this year. :)
