love the Rubbermaid container - did you cut that down to fit or were you able to find the right size?
Hi Greg, no I had to measure and cut it. The container was so strong that I needed to use an electric jigsaw to cut it.
I will be curious to see if the Downey leaves a residue over time in the dispenser
It's flushed really well with fresh incoming water so I tend to doubt it, but time will tell. If I find that residue is being built up and I need to clean it often I will start flushing it with warm or hot water.
Robert, what is that rod-like grey thing in the lower left (the hand your're writing with) corner of the picture in post no. 227204?
That is the side of the lid just pushed over, it's just a temporary lid and is not connected by hinges.
do you use a special method for drilling holes in vitreous enamel?
Theo yes I use a lot of heavy plastic tape on both sids of the porcelain object I am cutting, this helps to prevent chipping.
What's next?
The next thing I would like to do is resdesign the detergent dispenser so it is on the inside of the machine. Because of the tight clearance between the top and the wash tub it is going to be a challenge, but I have some ideas to try.
