Indesit 2527 User Manual
wravenant
Feb 17, 2015
3
Hi
I have an Indesit 2527 washer/dryer in working order, but I can not figure out the programming.
Any help would be greatly appreciated, I see some people refer to it as the WG 525, not sure though.
It has the 2 knobs, one for washing and one for drying and then 4 buttons.
It is in South Africa.
Can anyone maybe email me a user manual so I can use this great machine.
Please and thank you.
Indesit
Without any knowledge of this particular machine it is likely that it operated in more or less the same manner as any other. I did have a later Indesit manufactured washer dryer however and this is my recollection of how it works. A close up picture of the knobs and buttons would be a great help.
The wash knob will likely be in two or three segments. It may be that the dial may have the international symbols on it which will be a great help in working it out.
Turning clockwise the first segment will be for washing cottons and sturdy fabrics - the first and possibly second positions are likely to include a pre (or second) wash. As you rotate the dial the wash temperature for the programme will reduce and will probably be 90, 60, 40 degrees. This sector will have a more vigorous washing action. There are likely to also be positions for rinse and spin and (long) spin only for items which have been washed by hand.
The second segment will probably be for what we in the UK call Synthetics and US refer to a Permanent Press. The temperatures here are likely to be 60, 50, 40 and maybe 30 degrees and there may be prewash options too. Also there may be rinse and spin and (short) spin positions. This will have a gentler wash action. It may also be the case that at the end of this segment you have to manually advance the knob onto the final spin cycle (known as rinse hold) to prevent the synthetics getting too creased.
There may be a third segment for delicate items like wool or silks.
On the dryer knob I suspect that there will also be two segments - one for higher heat and longer dry time and one for lower heat and shorter dry time. If there is only one time segment it is possible that a lower heat can be selected from one of the push buttons
In a machine of this age I presume there will be three compartments in the drawer main wash - larger compartment, pre wash - smaller compartment and a trough for fabric softener.
As I recall it the buttons on mine were for On/Off, half load, one to activate the dryer (you could press this in at the start of the wash but its better to take the clothes out and shake them out between spin and tumble dry and the drying capacity will only be 50% of the wash load). There may be a no spin or rinse hold button as well, but a close up would be a great help.
Good luck with your machine
Al
Isn't this the same machine as the colston
wash and tumble dry, I know there are threads on the colston machine, so looking in the super searcherlator should bring up the information you need, though what Al says makes perfect sense and is more than likely correct.
Mathew
Colston
Yes this is a Colston machine - also see RIBA.
progs could be numbers or letters but the prgrammes ought to be the same in the same sequence. colston had habits of skipping letters for example our 950xd goes A B C E ......
1 bio pre wash INDEPENDANT(40 degs)this prog should stop at the end of this cycle.
2 prewash (40 degs) THIS PROGRAMME COMMENCES INTO THE 90deg wash
3 90c cotton
4 60 cotton
5 40 cotton
6 rinses
7 final rinse
8 spin
9 prewash commencing into 50 deg wash
10 50 synthetics
11 40 synthetics
12 40 woollens
13 rinses
14 final rinse
15 synth spin
13 or 14 could be the start of the rinse or the final rinse depending on the machine.
buttons will be....
from left hand side
1 tumble dry button - use to commence from spin into dry without pause @ STOP
2 spin speed - out is 800 in is 400
3 no spin
4 on/off
Hi guys
Thank you very much for the great advice.
It is really appreciated.
Please see close up pics attached.
However, this morning when I tried switching it on, no joy, is there a specific start sequence, like power, on/off, water on, dial turn, or does the sequence of turning on the power not matter? Also, I only have cold water.
