Well i looked in my appliance file thinking i had a picture/exploded diagram for the pump on a KDS-17A, but i can't find the damn thing so i'll go from memory, having taken mine apart a few months ago.
Somebody correct me if i'm wrong, but as far as the 17A went, after the Hydro-Sweep arm was off, and the spring-tension press-on filter screen came off, the 4 screw bolts to remove the top housing (easy no special tool stuff-- Philips, IIRC) there was revealed an impeller underneath the top housing that was interference (press-fit) on to the motor shaft directly. My thought was this impeller disc was made out of a bakelite material, very brittle and easy to crack, but the point is that on my 17A it was a direct-connect to the motor shaft. Short of a major leak between the upper/lower pump body housings, pump displacement/flow should be directly connected to motor speed. Eggs, again IIRC, are a very difficult test for dishwashers because they are protein based and can be among the hardest thing to remove. Don't ask me where i saw that, mayhap an old Consumer Reports or something. I just remember egg material was a bear for any DW and especially DW detergents. Could be wrong, but something else to keep in mind. Make sure the filter screen assy is nice and clear of obstructions, that is the main intake filter for the pump, and that the pump, once you can see it, spins easily by hand with minimal or no drag, no roughness or growl/grind noises (bearing check), no obstructions in the flow channels molded into the housings. Another source of drag i found is the upper housing that the spray arm spins on. Some have a bronze (?) bushing surface and some have a plasticy top that acts as a bearing for the Hydrosweep to spin on. Most of all be extremely careful if attempting to pry or pull off that pump wheel itself, penetrating oil left on for 1/2 hr or so combined with LIGHT tapping on the motor shaft while spraying might help pull it off if nesc, but me had no luck-- cracked and came in pieces, luckily i had a spare motor/pump assy on hand. Hope this helps!
-MH
