Interesting mid 60s GE washer ad
bradfordwhite
Nov 16, 2019
3,878
central U.S.
Never saw this model. It must have been short lived.
The mini-basket is familiar but that auto-advancing timer controlled panel looks like it's from another planet.
Looks like a TOL Americana feature-wise, but lacking the fluorescent lamp.  Definitely a programmed washer with possibly and extra rinse option.  If no date is indicated, I'd guess about 1966 or 1967?
lawrence
An “All Push-Button” Washer from GE, and from Australia?
I’ve never seen an all “push-button” Australian washer from GE before. I did see one from America before (with a lighted back guard below the controls — 1964 or 1965).
Does this one have a lighted console?
It looks like it doesn’t.
Nice looking washer, but definitely different looking from the American version.
I’m also going to mid-late 1960’s for this one.
—Charles—
We obviously have/had the technology in the U.S. for a self-advancing timer console.
Who hasn't seen or even used a GE coin-op?
It's probably safe to say they used the same timer.
That looks fun, I have to admit. It even has a sudsaver feature and Panel lights that scream PARTY TIME !
Have you noticed the three switches under the panel?
Any ideas what they do?
Keith, that GER coin-op you cited above, didn't have any kind of rapid advance timer mechanism.  It just had a standard  cycle.  with it being a 2-speed washer, the buttons just varied the wash/rinse temps and the wash/spin speeds.
Bob, even if they are using just one cycle, it still has to self advance at some point, wouldn't it?
Unless you're saying there is a continuous timer cycle for the wash actions AND
another timer that only allows the machine to run for a certain period of time once the coins are inserted with that time being the amount of time it takes for the cycle timer to revolve through one cycle.
I've only helped a relative to service a 'front servicable' mid 70s GE FF coin-op, similar to the one in the photo, once in 1981 but we had to replace the motor and clutch. Didn't do anything with the timer.
When one looks at where the console lights are on the non-coin-op model vs. the home model, it looks like they're in the same place.
I'm thinking they deleted some of the features for the coin-op, like the suds return and other cycles, then wired it to only use the one cycle. Then when you put the coins in it auto advances to that cycle and completes.
Coin-Op GE Washers [ And Most Other Brands ]
Did not have or need a rapid advance timer with an extra motor to start the cycle, this machine would not have used the same timer or one even close.
Bib is correct, on a Coin-Op machine when you put the coins in and push the slide in you actually are pushing the timer ahead to start the washer.
It looks like this cool machine is a full sized 27" model, GE also built 24" wide models in the US around this time, and they built and sold a lot of 24" models in other countries.
" Coin-Op machine when you put the coins in and push the slide in you actually are pushing the timer ahead to start the washer."
That would make sense. I simple one cycle timer with a break at the end. I'm sure GE, or who ever made the change box/timer combo, wanted to make it as simple and maintenance free as possible.
Thanks Bob and John
I never knew until recently that GE made 24" washers. I thought that was a Whirlpool/Kenmore thing. Never saw one in my life. Was that short lived ?
I had a GE with the timer but had holes in the back console where the coin box would go, The timer went just past the top to fill and back around to the top to stop. Plugs covered where the temp and level switches would be. 1 cycle, 1 speed. Last I knew my old tenant was still using it. The coin box pushing the timer to on makes sense.
