Ironrite ironer in Wood Cabinet?
mattl
Sep 17, 2007
6,334
Flushing, MI
Wandering around a bit this afternoon, looking for a large mixmaster bowl, but came across something interesting, there was a large wooden cabinet, looked from the late '40s maybe early '50s and it said Ironrite presser on it.  I've seen lots of mangles in metal cabinets but wood?  Is this rare?  Any idea of the relative value?
wish I would have taken a picture....
I have one.
I believe it's a model 88. It was intended for use in a home without a basement or dedicated laundry room. When not in use, it is supposed to blend in and look like a piece of furniture in a bedroom or living room. Functionally, it's the same as any other full size Ironrite in production at the time. Mine has a delivery receipt saying 1951.
Dave
Those Wood Cabinet Ironrites Came In Many Flavours
Some were dark wood. Others looked like the "mod" furniture design craze that was popular in the 1950's and 1960's. All as another member stated were from the idea to have an ironer that looked like furniture to deal with tight living quarters.
If the home lacked a dedicated laundry area and or basement such as an apartment one could have one of these furniture designed Ironrite in the living or any other area and not have that big white porcelain thing clashing with the décor.
Units were not a huge seller in many markets as housewives didn't always warm to clean not and steamy ironing coming in to contact with wood. IIRC some of the models worked around that by having a metal base and just a wood lift off or up/back cabinet.
They are asking $90, part of me always wanted an ironer - so I'm a little temped.  Anyone know if these are 110 or 220?  I believe our neiaghbor when I was young had a mangle and it ws 220, but not sure.
My aunt had the iron rite in wood cabinet was great mom had the white metal one.  They are great machines.  I think all the iron rites here in the states would be 110.  $90.00 to me is a good value.  Lots of folks here can help you with learning to use it.
IIRC All Ironrites For Domestic USA Use
Were 120v (or 110v *whatever* LOL)
Ironrite did have a gas heated version that was sold under the Maytag brand as well. These are VERY rare and have only seen them on eBay and that was years ago. Ironically it was both a Maytag and Ironrite unit being sold as set. IIRC they came from a closed laundry or dry cleaners.
Was young and new to appliance collecting then so didn't bother. In hindsight would love to have one of those gas units today. Unlike the Simplex gas heated ironers the Ironrite models allowed control of temperature.
If You Find One Let Us Know
*LOL*
One assumes these gas heated Ironrite and Maytag units were sold for commercial use and perhaps a certain segment of the domestic market.
For the former heating for ironers and pretty much anything else electric is usually low down the list after steam and natural gas, propane and even oil (for certain types of ironers). Steam makes sense since many large commercial laundries already had boilers going to produce steam for everything from heating wash water to ironing. Am told much of this came down to cost, in that electric rates were almost always higher than gas, especially for the amounts a laundry uses.
Simplex was the first and probably the only other maker of domestic ironers that heated with gas. One must say can see today why the thing would no longer fly today and possibly be considered dangerous.
Until worker safety laws and or legal action forced a change many operators of gas heated ironers in commercial settings suffered all sorts of health problems. Much of this had to do with the fumes that come from combustion especially incomplete. Then there are the issues of leaks etc... This is why today gas heated ironers in commercial setting are always used in conjunction with some sort of venting system and or other ways to bring in fresh air and remove the fumes. You can still find smaller gas heated ironers on the market today for commercial and "small" use such as in a hotel or B&B. But one imagines local codes speak to make-up air and worker safety.
Early Simplex ironers could burn Naptha, gas, gasoline and IIRC even alcohol! *LOL*
One thing in favour of using gas, steam or whatever instead of electric is that you get more heating and faster recovery for your buck. IIRC most early domestic ironers sold in the USA topped out at around 1650 watts of heating power. That gas Ironrite could probably blow that number away.
BTUs Of A Gas Heated IronRite
Just as with Electric dryers and gas dryers there is VERY LITTLE performance difference between a gas dryer and an electric version of the same brand and model.
If you take the average wattage of 1650 watts for a regular IR ironer, the 1650 watts translates into 4950 BUTs of heat and when you consider that the electric heated ironers lost little heat and that the gas IRs were 5000 BTUs it is very likely that the home style electric units were faster than the gas ones. I would also guess that the Gas IR you found was strictly designed for home use as it is not powerful enough for continues production of a laundry.
ThorGlad Iron
Has the highest heat wattage of any ironer one has owned or seen that ran on 120v. Only my 208v-240V Pfaff ironer from Europe is higher with 3Kw. Early Miele 220v ironers sold in the USA are about the same but the 120v version drops to around 1.4kW or maybe less. Their latest offering the B990 is even lower IIRC.
Suppose much of this comes from modern codes about drawing no more than 80% of a load in continuous use. Since domestic ironers then and now sold in USA only required 15amp supply Hurley was pushing far back in the day with 1650.
Regarding the gas Ironrite/Maytag ironers, then as now some dry cleaners and laundries have "homestyle/domestic" units instead of commercial or even quasi-commercial units. Miele does offer a commercial version of their ironers but no small number of places use the "puny" 120v powered unit instead.
One supposes it all comes down to how much ironing a place does via a mangle versus the associated costs of going professional.
Do know among those of us who collect/use vintage ironers the feeling is strong that the older units get much hotter than today's offerings. Indeed the Thor GladIron could scorch linen if not set properly . I know this because when I got my first turned the thermostat to the highest number because it said "linen". Well one pass of the first napkin came out "burnt". *LOL*
Did Some Quick Research
Miele (the only ironer still sold for domestic use in USA) has reduced the heating wattage on their latest offerings to 1kW. This compared to their early 208v-240v units that pulled 2.5kW or a bit more with heating elements of 2kW IIRC.
Miele does now offer a commercial unit that has a steam function which runs on 208v-240v which one assumes has greater heating power.
When it comes to ironers greater heating power serves two functions. While of course the major role is in reaching the desired temp for ironing particular materials, there also must be enough to maintain said temp or return it quickly as the shoe is cooled by passing damp textiles.
Gas Heated Ironers For Domestic Use
Did some research and it appears one of the reasons behind Simplex and others offering gas heated ironers for homes grew out of electric supply. Basically either lack of and or homes without proper wiring to handle the nearly 2kW of power needed to heat ironers.
Somewhere this must have changed as ironers even later Simplex models began to feature models with electric heating elements at 1.5kW to 1.65kW. Am going to assume this had something to do not only with the invention of heating elements (Calrod?) which also greatly also changed the electric clothes iron market, but the wider spread of electric power and better household wiring.
Still pulling 1650 watts of power from a 15amp/120v seems pushing far IMHO, especially since modern code recommends no more than a continuous 80% load. Have never seen an ironer vintage or new that ran on 120v recommend a 20amp circuit.
MIele's newest ironers for the American market have heating elements rated only for 1kW. That is a far step down from the older 208v-240v units that pulled 2.7kW to 3.1kW. Not sure what their 120v units before the B990 required.
