Well I bought an LG 3570 front load washer and dryer and they both perform nicely. You do not need to spend $2000 on a washer and dryer set to get a reliable washer and dryer. LG's are consistently #1 in reliability for their front load washer and dryers. These can be stacked and they also do quite well with pet hair and since I have 4 cats, I know!
On the washer I use the TurboWash feature that recirculates the water onto the load by using two jet nozzles in the front, it also uses an overhead jet to spray rinse the load during the final rinse. That jet spray kicks on for 2 minutes in the final spin, it also sprays during the first spin and if you add rinses, you can add up to 3 deep rinses, it will spray rinse during each spin. Stain removal has been superb. I use Persil in the washer and the results have been amazing. The washer also extracts water well. The high speed final spin speed is a cool 1200 rpm. The Ex High spin is 1300 rpm. I find more wrinkling occurring at that speed than 1200 and no difference in extraction. The washer isn't shy about using water either. The only thing I would suggest is that if you have high water pressure like we have here, is to get water hammer arresters and put them between the washer and hoses. This washer likes to use rapid opening and closing of the water valves during the wash cycle.
The dryer is equally impressive. Its very quick in drying and quite accurate in sensing. It uses tow systems...one is electronic to feel the moisture in the fabrics and the other is a humidity sensor. They work very well together and I never have to use more than a Normal dryness setting. The Sensor cycles have preset temps that you cannot change. Cotton/Normal uses a Medium Temp and it works quite well even for jeans. Towels uses Mid High Temp and Perm Press uses a Low Temp. The dryer will also show a preset time like 41 mins for Cotton, 34 mins for Perm Press and 55 mins for Towels. The dryer will add time or subtract time based on load size, and how fast the load is drying. I find most loads finish way before the washer ends.
The washer also weighs the load and bases the cycle time on that weight. I have seen some loads take as little as 35 mins on Cotton Normal and close to 1hr 20 for a large load.
The other nice thing is that they are both quiet. The dryer is perhaps the quietest I have ever used. The washer is equally quiet and the drain pump is almost silent. The build on these are quite nice as well.
