It's a good weekend for a new (to us) Frigidaire Range!
Quick question, do the front panels on the '63 models tilt down like this?  I need to clean the clock glass, but cannot figure how to get at it.
Well, cooked another meal on it last night (see photo), so far so good! I made spaghetti with meat sauce, used three burners and the small oven for the garlic bread. Everything turned out perfect! I think I'm really going to like the infinite control on the burners.
The clock doesn't work - the second hand spins, but the minute and hour hands don't move. We tried tinkering with it but think one of the gears is bad. I had a lovely exchange with General Time Repairs, and they said to send it in, they'll be able to fix it, because it's a GE clock assembly. They needed a number off the back of it, so we pulled the range out last night and took the back panel off so I could snap a picture. Prices are very reasonable, and the woman I was dealing with was super friendly and helpful. So we'll send the clock off at some point soon to be rebuilt.
Robert tried Tom's 'click test' yesterday, and no luck. While we had the back panel off, we investiated the Speed Heat switch and found the part number on the switch that is in that slot. Checked it against a parts book, and unfortunately it is just a regular infinite switch. Phil had sent us some specs on testing the burner element to see if that was still the original Speed Heat burner, and as we were going to pull it out, Robert spotted a part number on that as well - just a plain-jane burner. Oh well, we agree that at least we have four operational surface units, and at some point we'll find the parts we need to get it working as original again.
We do know that the Heat Minder was replaced, probably in the early 60s, as we found the replacement instructions tucked inside the back panel. There's also an updated wiring diagram for that fix stuck to the back of the range.
Happy Frigidaire Cooking! Yay!
My clock died a few years ago, it's on my to do list, but low priority. Does the company you used have a fixed price for repairs or is it case by case? Last time I looked I noticed the contacts on the timer for the oven were in very bad shape, I guess it's the decades of current flowing through them, but mine need to be replaced.
Did you replace the fluorescent tube? Mine is still original, wondered how hard it would be to find one.
Yes, the company uses a fixed price. It's $95 plus $15 shipping, which I think is more than reasonable. If they have a rebuilt clock in stock, they send it to you and you return your broken one. If they don't have one in stock, as is the case in our situation, you send it in - they repair it and have a same/next day turn time. If it's a GE, they assured me it can be fixed!
http://www.generaltimerepairs.com/
The fluorescent tube and starter were both in stock at our local Ace hardware - they're pretty standard, I imagine. It's a kitchen and bath bulb.
Personally..
The Radiantubes are my favorite electric units, they don't rattle when you walk across the floor, and the porcelain bowls and removable rings are easy to clean, the heat imho is better distributed too.
I love radiantubes as well. Part of this stems from the fact that I learned to cook on 5-heat radiantubes as a older child and teenager. Our 1958 Frigidaire Deluxe 30" range was around until the early 1980s. When it was scrapped, it was unfortunately replaced with a WCI Frigidaire that only lasted for about 10 years.
Fred, my speed-heat DOES work as Ben and I replaced both the switch and the element with NOS parts before I bought the range from him. It's pretty amazing that when you turn it to HIGH and when the latch releases the 240 volts after about 30-35 seconds the element is already glowing very pale red. After 1:30 it is bright orange-red. The small rear element takes about 4 minutes to get to bright orange-red.
My heat-minder also works and appears to be original (it's possible the element itself has been replaced, but it was with a GM part if it was). It was the last year of the first design (1955-57) that still used a 3 wire element, a two-stage capillary sensing system as well as a pulsing relay. So far, I have found that it is quite accurate for simmering operations but that at the higher end, it can swing rather wildly in the "fry" section.
I would imagine that you have the service manual for your range.
Have you acquired a Kant-Slide griddle yet? :)
Here she is with all of her accessories...
We searched the house high and low for these, I'm pretty sure we found everything. There may have been some inserts for the deep well, but we can live without those for now. We also didn't find the small broiler pan.. An original Frigidaire one would be nice, but I know we'll find a broiler pan at some point.
The deep well insert ,'radiant wall, spatter free broiler grill', and the kant-slide griddle, with its broiler insert were all in different areas of the basement, and the temperature probe was in a box in the garage.
Your deep well cooker looks to be in pristine condition.  The lid on mine is no where near as shiny.  There is a rack of sorts for the deep well, holds custard cup and such as well as a fryer basket, I'm sure you two will hunt those down at some point.
I should get to the Post Office tomorrow...
Fred,
As far as I know Frigidaire Ranges either came with a porcelain-coated broiler pan, the aluminum broiler pan or the aluminum "radiant wall splatter free broiler grill" but not both!
The radiant wall broiler was available separately for those who bought lesser models but it came as standard with the Custom Imperial models instead of the porcelain-coated one or the small aluminum broiler pan.
Beautiful Range.
I miss my Pull and Clean Oven.
With that feature, I just about cleaned my oven everytime I finished using it. Once you get used to the Radiant Tubes, I have found there is nothing like a Frigidaire Range to cook on.
The Ovens on these earlier ranges seem very well insulated. (I noticed they stay warm quite a long time after you shut them off).
The styling is just beautiful. Although I am a fan of the Calrod GE range, I had no trouble adjusting to the Radiant Tube. My Grandmother taught me the most cooking on a Frigidaire Range.
The griddle and its rack constitute a small broiler pan according to the literature with my '54 range. Also, according to the same manual, if you prepare bacon, putting the bacon strips in the griddle pan and then inverting the rack over them helps them to cook flat and eliminates the need for turning.
I do most of my broiling in the small oven of the '61 and usually use the small GE broiler pan. I have the floor of both ovens lined with foil and for broiling, I took 2 pieces of heavy duty foil and folded each piece into an "L" shape to cover the rack beyond the broiler pan and the side walls up to the top of the oven. Frigidaire broilers are very high wattage, over 3000 watts in the '61; I don't remember if it's 3450 or 3700, so there is popping and they really broil well, but the foil keeps everything clean.
