Maybe I'm just on a run getting them. It won't last but I will enjoy it while I can. These came thru the haulaway pile the other day. QSD-DAN got these. I think that between Kevin and Dan, it's going to be a pill for other states to find extra available power...
Washer first look. I got it without the lid. Drat! Otherwise pretty good shape. Wondered about the top where there might have been a model tag. The tag is actually on the back like it should be. Hmmm... Yet another customer who cannot figure out how to rinse out the cup...
Well, Dan drove over and took advantage of the shop and we went thru the washer. After washing out the inside, it looked preyyt clean. You could see the damper pads that came loose and were hanging out but luckily the damper survived!
Removed what was left of the old pads and cleaned all residue off the base. A mixture of wire brushing and acetone to prep the base. Glued the pads on and let the glue set.
Gave it a test spin and even though it spun well, you could hear the 'quack quack quack' of the tub bearing due to age and wear. Since I had already showed Dan how to rebuild a HOH dryer, he decided to have me show him the ins and outs of changing a tub bearing and seal on this one instead. I actually took pictures of the whole process and will post in a separate thread for those who want to see how to do it complete with helpfull tips if you want me too.
So in went the new tub bearing and seal! This washer should be good to go for another 20+ years!
Reassembled and put her thru her paces. Since we had totally tore this washer down to the frame and reassembled, there was a little worry about it holding water. Winner! an used a new tubband clamp gasket ring for extra measure. Some thoughtful soul had already updated the injector assy before I got it.
Nice strong agitation. I love that gentle 'thrum thrum' that only a happy, healthy Maytag helical transmission can make. Dan watched closely to see if his new baby behaved herself. Of course, I shot a little video. And yes, Mickeyd, the title is '1974 Maytag HA806 agitate & spin' ;^)
So here they are. Dan will overhaul the dryer at home. They did clean up really well. Dan had a spare lid although the color is slightly different. Close enough for govt. work...
Was it Ben that started this tradition? Ahhh, anyway here it is. Soon to be going back to California and put into service. Dan promised me a picture of them in place and working. RIGHT, DAN?
