Tub seal and Bearing
The tub seal and bearing were bad, and were replaced. The guy said I used too much soap. I denied this and hopefully could place the blame on my partner. (Who was standing there at the time) But he also said that cold water rinses could cause the build-up too. Cold water is defined as 75 degrees, and most of the time is much colder than that. Well, I am the one who uses cold water rinses, so the guilt shifted back to me.
I have been using powdered Tide, Free, and with Bleach, since I got this machine. We think we will switch to Liquid Tide.
Here are the parts that were replaced. You can see the white coating of the three parts in the middle of the picture. That is the mounting stem and boot seal. I think the mounting stem rotates above the boot seal. Personally, I think it should have lasted longer. The lower pieces are the bearing, which is a tube that slips inside of the upper rubber piece which is what goes under the outer tub. That bearing is just one tube inside of another.
Anyway, I am glad to have it back. At least it was repaired, not tossed out. I would have had to buy a new set, because of the location in my kitchen. Next time it fails, in 8-10 years, or hopefully longer, I will get a new set.
Martin
