just went info on aw members who owns speed queen tc 5 or maytag Maytag Commercial Model MVWP586GW
pierreandreply4
Sep 7, 2007
2,591
St-Bruno de montarville (province of quebec) canad
this morning did a load of laundry and set the washer dial to clean washer reset washer by unplugging 1 minute replug and then after putting load to dry run clean washer cycle that suppose to be tap hot i was near the washer start to fill hot but then suddenly switch to cold its clear that my mom will need to take a decision because i feel or washer is a lemon not working as it should since its clear its a bad control board that i have but as a precaution i am gathering info incase the tech reccomend replacement so i went onfo on members who owns the speed queen tc5 on cycle lengh options no options all cycle and the cycle lengh of the
Maytag Commercial Model MVWP586GW i might be a bit strict on that side do not went something full electronic and need to be a washer that do a load under 30 minutes not an hour or 2 hour, 3 time i alerted my mom that we should have the washer check out i even took a pic of the fault code in the tech menu as well as check online i also apologise for my small vent but as i said curently gathering info​
