maytaglover68
Got in an Amana NTW4516FW3 top loader (made on 36th week of 2019), they said it stopped spinning their clothes out. Thought it maybe be a shift actuator, the pump, or even a locked up gearcase, but it turns out the motor has locked up. Spin the drum and heard weird noise. Took it out and spun the motor by hand and I heard it grind and I was able to press it in and out. I don’t think I’ve ever seen a VMW do this before. Yep, a bad motor.
Apparently this person on YouTube had found a washer with the same issue as the one I got in. Spun the drum by hand and heard the same squeaky and grindy sound.
Link to Redo’s YouTube video:
This is the exact symptom that the washer I got in had, belt cover melted, same motor issue. This motor part number is W10623547 and it’s a Welling brand. Never seen a motor fail this way (at least don’t remember) throughout all my years of being an appliance technician.
Glad I have a Whirlpool WTW4800XQ4 washer and Amana NTW4650YQ0 in hand with a roaring gearcase and bad suspension rods but a good motor, although the transmission bearings and suspension rods are bad on these two machines the motors are good, I also have several other scrap machines with good motors so I can put it on this and be good to go. This isn’t a Maytag so it doesn’t have the 10 year warranty for the motor.
2016 Maytag MVWC565FW0 washer I got in, this person said it had a belt issue due to it not spinning and they said it shoke violently before it stopped spinning, although I rarely get VMWs with belt issues. The actual issue was bad suspension rods, a bad basket hub and a wallowed out tub sleeve, now it’s fixed. I’d be interesting if it was just a belt but it wasn’t. A lot of people seem to think their issue with the washer is just the belt.
Or I can maybe part out this Amana NTW4516FW3 washer since it’s got many good parts. The belt cover won’t be saved because it’s melted due to it overheating. But I can get the gearcase, the suspension rods, the drain pump, the lid lock, and the agitator out of this one and use them on another machine.
