KDS-16 help
kenmore71
Bronze Member
Sep 20, 2010
1,724
Minneapolis, MN
Some of you may recall that a few weeks back that there was a KDS-16 in Minneapolis posted on here. I have come into possession of this machine and am seeking some advice. Mechanically the machine seems to be quite sound--in that it doesn't leak, the wash arm seems good and the water valve & drain solenoid all seem to operate properly. Most of the time. After an evening of "playing" with the marvelous and frustrating beast I am 90% certain that the troubles I am experiencing lie in a badly worn/failing cycle selector switch.
This is an early KDS-16 without the Soak cycle. Can anyone help me in locating the PART number for this switch or better yet offer one up that they know is good? I really think that the timer on this machine is good but the switch is sticky and only seems to select an operating cycle about 20% of the time after significant fiddling. Once a cycle is actually selected it completes just fine...unless you open the door and then all bets are off on getting it to start again. The ONLY button that seems to work faithfully is "Cancel" :)
A vast array of photos will follow after I am properly caffeinated...
I think they COULD be interchanged. They are a different switch but the only difference that I can see in studying the schematics is that on the pre-soak machines the Sani-cycle uses the Heavy Wash program and the the Soak machines use the Normal program. Off the top of my head I think it could create odd cycle behavior if you actually chose the Sani-Cycle. If you knew to avoid that I think it would work just fine. And, really, WHO uses the Sani-cycle???
So, trade ya a functioning Maytag 740C for a KDS-16 switch? :)
Houston, we clearly have a problem here!
Right now neither the fan nor heater operate during the cycles. I haven't checked yet to see if this is a selector switch, timer or actually fan motor issue...
If you need/want to change this over to a soak machine, I have a timer, push button set and control panel off the soak machine.  I'm taking a guess that the wiring harness is the same...
Bottom racks and the heater boxes are always in stock at Casa de Swestka.
Ben
part number on timer
I don't know if you have found a switch yet, but if you can give me the part number on the back of the switch, I will see if I have one. I have I think 2 new in the bag switch assemblies so maybe you will be in luck.
Just let me or all of us here know.
I have encountered sticky selector switches on KitchenAid diswashers before and I have used WD-40 and squirted it in the switch with the power disconnected of course. I then gently move the switch in and out repeatedly until it works more smoothly. This has been a successful repair if the buttons are stiff or if the buttons won't stay in, etc.
Just a quick update...the machine is working well and I appreciate all of the advice and offers for the needed parts from the wonderful community here! Those who have offered help have all been contacted privately. I have decided to keep the machine and think I'm going to install it as a second "chef's dishwasher" in my kitchen. I do a lot of canning and baking and it would be nice to have a short-cycle machine that scrubs the h**l out of things in short order. I may even remove the upper rack so that I have a machine that I can get big baking sheets, racks and pots in. Right now I have been playing with it in the basement and have been hardwiring it for the various cycles as I test it out. A new toy is always great fun!
Updates...
I have been continuing to make progress with the KDS-16.
Here are a few pics of the "field repairs" that have allowed me to continue working in the absence of replacement parts. These parts are coming but it may be a few more weeks...
Here's the control center!
That's a SPDT toggle switch. When in one position it activates the rapid advance timer reset. When in the other it is in the "run" position for the Heavy Soil cycle. Not elegant, but functional for now!
And from the back
I have a 3 relays that I need to pick up at Grainger later today that will allow me to remove the water heating elements, drying element and the pump motor from the timer. I'm hoping that this SHOULD extend the life of the timer almost indefinitely to not have any heavy loads running through it. As part of this I will also couple the 2 700 watt water heating elements to BOTH operate whenever the timer calls for a single element. This will require running that power through a relay and making sure that main service to the dishwasher is a FULL 20 amps and wired with 12 gauge wiring.
In tests that I have run, this has resulted in 140-145 degree water for the final rinse of the Heavy cycle with the water heater set at 130 degrees! And It's done washing and rinsing in 28 minutes!!!
I also plan to install a toggle switch on the lower righthand side of the machine that will turn the drying heating element off for use in the summer when I don't need 30 minutes of steamy air from a 1000 watt heater pouring into my kitchen!.
Great!
Very good idea to use relays instead of directly running the heating element/motor through the timer. This is probably the weak spot on many washers and dishwashers with timer activated heating elements, I'm afraid, just as it is with control board models of today, and yesterday. Your timer should last forever now :-)
Also liking your neat fix on the heater duct - though I hope that you'll eventually fix that properly?
Up and running!
I have spent the last few days slaving away on the KDS-16 and yesterday brought it up into the kitchen and semi-installed it. Here's how it looks! I know some of you will be chuckling...
As you can see, it matches my sink and countertops beautifully!
And, yes, that is a glass of bourbon on the countertop to help celebrate a job completed (for today, at least).[this post was last edited: 3/22/2013-14:26]
A little closer...
I have a couple of leads on a butcher block top. For right now this top was made from scraps found in the basement.
Also, relays have been installed on the water heater and the motor.
I have disconnected the heater in the drying duct for now and am only using the fan to "air-dry" the dishes. So far it seems to be working pretty well. Perhaps when I find a slightly newer aluminum (as opposed to galvanized metal) duct I'll play around with heater drying again. Quite honestly in my little galley kitchen that drying element may throw out more heat than I want!
And the improvised "control system"
Again, I have a lead on a switch for this machine but it may be a month or two before that comes to fruition. In the meantime I wired up a little temporary job with off the shelf toggle switches that were already in my toolbox. The left switch is a DPDT switch and is wired to provide "Heavy Soil", "Off", & "Light Soil". The right switch is a SPDT switch that resets the rapid advance timer at the end of the cycle just like opening the door would.
If I had wanted to get even fancier, I could have added a 3rd SPST switch that would have turned the "Sani-heat" delay for the final rinse on or off.
And Heavy Soil which uses 16 gallons.
These were not terribly eco-friendly machines in that regard.
This was not the thirstiest of the KA machines, though, the KDS-17 would use 18.9 gallons in it's Soak/Scrub Cycle!
Correct me if I'm wrong, but I think the nearly 19 gallons that the KDS-17 used was the record for a home dishwasher cycle. Were the GE PotScrubbers that thirsty?
KDS-16
Mark I do love the added switches where the push-button switch used to be, I especially like the little bit of wood-grain around them.
This reminds me of the frist Kenmore BD washer I got when I was 14 that I wanted to fix, it was a 1959 LKM that one of my Mothers friends had given up on and it had timer problems. My Aunt Margret had just replaced her 1955 MOL KM washer and I went over to their house before the Sears guys hulled it away and took about every electrical part off the old washer including the complete wiring harness. I then took the complete PB-Timer assembly out of the 59 LKM installed a piece of 1/4" wood paneling and installed the timer and water temperature controls through the paneling, it worked fine and our family used it that way for a while, so your clever conversion really brings back memories.
I will try to round up the parts you need this weekend and get them shipped, John.
