Some of you may recall that a few weeks back that there was a KDS-16 in Minneapolis posted on here. I have come into possession of this machine and am seeking some advice. Mechanically the machine seems to be quite sound--in that it doesn't leak, the wash arm seems good and the water valve & drain solenoid all seem to operate properly. Most of the time. After an evening of "playing" with the marvelous and frustrating beast I am 90% certain that the troubles I am experiencing lie in a badly worn/failing cycle selector switch.
This is an early KDS-16 without the Soak cycle. Can anyone help me in locating the PART number for this switch or better yet offer one up that they know is good? I really think that the timer on this machine is good but the switch is sticky and only seems to select an operating cycle about 20% of the time after significant fiddling. Once a cycle is actually selected it completes just fine...unless you open the door and then all bets are off on getting it to start again. The ONLY button that seems to work faithfully is "Cancel"
A vast array of photos will follow after I am properly caffeinated...
