KDS-16 Does not fully drain.
During the last two to three uses my KDS-16 Dishwasher is not fully drained when the cycle ends.
I observed the functioning of the machine and the drain value does activate at each transition of the cycles and I see the water pouring into the sink drain from above but when the cycle is finished and I open the door there is still water inside. I push the “Cancel Drain” button and the remaining water evacuates out into the sink drain.
I read a thread from 2011 and the items mentioned were timer, overfill valve, and drain solenoid. Not sure any of these are my problem.
Other than possible solutions for this situation I am wondering if it is safe for the machine to be stopped to open the door at each cycle transition to see the water levels etc. I never counted but I have to think that would be about 8-10 open and close on and off cycles and don’t know if I will damage the machine doing that.
How high should the water be at each fill cycle? I assume the water should be nearly totally evacuated at each draining operation.
Your experience on these levels and the safety of opening and closing the door would be greatly appreciated.
Also two other things are going on that may be related. I have had a change in the motor noise. For a few months now the noise was a constant buzzing or humming noise that quieted down once the machine is filled with water. Now it is a sequel at the beginning that stops about midpoint in the 1st prewash and then the machine is pretty quiet. Also while it was making the buzzing or humming noise when it was draining I could hear a dry pumping type sound as the last amounts of water squirt into the sink drain. I know longer hear that dry pumping sound. This makes me wonder if the drain impeller is not pumping efficiently enough to evacuate all the water in the allotted time. I have thought to look in the pump housing but the screw on the top of the wash impeller seems very tight and I don't want to turn too hard to the left in fear of breaking off the screw in the motor shaft. Any tricks on how to free up that screw? (vinegar, liquid wrench veg oil. ect)?
Also I am in the process of replacing the drying motor and when it 1st failed and wouldn’t start to see if it was the timer I manually advanced the timer gently very slightly one click. Don’t know if that has caused the problem. Again the cycles function in the correct amount of time, I see and hear water flowing to fill and drain and the shaft returns to the correct position at the end.
I really enjoy having this great machine and hope that I can correct this situation.
Thanks in advance for the advice.
John
John
