KDS-18 with drain problem
KDS-18 Draining problems ?
Hi greg, these are usually pretty easy, either a clogged drain valve, bad DV or a broken drain Impeller in the pump. [ or household problem like a clog in the drain line ]
If you are going to use a used KDS-18 DW you probably should be taking the drain pump apart and inspecting the main seal and probably replacing it anyway.
John L.
i would also
guess that it's either the drain valve itself or possibly a disconnected or loose wire to the drain valve solonoid.
i also agree in that if you are planning on using this machine on a regular basis a new pump seal would be the best thing to do, tune up wise. you can get em on ebay, i bought a couple last year and rebuilt a kds-18. i'm sure they are still available and i can get the part no if you want it. dont know it offhand but i can check my seals and find one.
i have a lot of kitchenaids of various models (about 24) and i have never run into a timer problem yet. it's probably something simple like a loose wire. good luck with it if you get it, we can help you change that seal also. lot of good info on this site.
