KDS-20 Leak
thechadwick
Sep 2, 2025
4
Hi all, I've had a new-to-me KitchenAid dishwasher for a few weeks and after a few runs it's leaking out the bottom. I'm guessing something rubber dry-rotted but wasn't able to identify exactly where it was coming from.
Also, the motor makes a loud buzzing sound and I'm wondering if there's anything else that needs maintenance work. So far we've just been waiting until we leave the kitchen to run it.
You'll have to run it with the lower panel and toe kick panel off. I suspect it's the motor shaft seals. When these start leaking, water makes its way down the motor shaft and into the bearings, taking them out. The bearings will be loud from this point on until they seize up and trip the breaker from too much amp draw. This is why I always recommend installing a seal and impeller kit if it has been 20 years or if one was just picked up. It'll save a motor replacement down the road, along with a potentially costly leak if it's on a wood or sub floor.
The lower panel can be tricky to remove and install. Here's an old video thanks to a member who passed away couple of years back. RIP, Ed
On mine, a few years ago, the hose clamp on the water discharge hose let loose a bunch of water on the floor and made its way to the basement. UGH!.... what a mess!
I put the hose back on with a smear of Permatex "red" gasket seal and tightened the clamp. - job done!
Last spring, another leak started, not as bad though.....
This time the leak was from where the upper spray arm hose connects to the pump housing. - that "L" shaped flexible rubber connector.
It's pressed into the lower housing from the inside, and the top housing merely presses against it. - thus, it was a dry seal that let water seep through.
Some Permatex "red" sealer cured that issue too.
And just for good measure, I ran a small bead of Permatex over the O ring seal before re-attaching the upper housing.
No more leaks!
We need an archive for all these old videos to easily get to! It took me 2 weeks of maneuvering the the bottom panel here and there to finally figure out how to put it back on 🫣
Ditto the others replies, I don't think I've ever dealt with a good old KD-anything that was leaking from anyplace besides the pump seal. If it's gotten noisy as well, the leak may have damaged the bearings. They put a slinger ring/disc on the shaft, but it's not effective enough for more than a drop or two now and then. You can probably pull the motor apart and replace the bearings by themselves if you're so inclined -that may well restore the motor to near new. There's nothing else that really wears out on the motor circuit besides maybe the start relay or cap (don't recall which they used).
This design, like the old GE washers with the great big dry clutch under the pump, was not so great. Even Kitchenaid with their commercial lineage and excellent quality doesn't last forever. One of the few advantages of the old GE "Sidewinder" two-wire DW pumps, though those were prone to stuck seals in vacation homes that sat all summer or winter. They had so little starting torque, they'd just sit there and hum...
p.s. they're not known for "quiet", even when they were new. they make all sorts of humming and chugging noises, depending on how far they've filled or when draining... there was never a doubt they were doing their job, no need for an LED projection on the floor to see if they were running, like nowadays!
Thanks everyone for the advice! I ran it today and it does seem like the pump seal. The leak is pretty slow and the external hoses are dry. I don't have a service manual but it seems like the pump seal kit 4162139 is a match? I'm finding a decent number of those on eBay at reasonable prices.
As for the noise, I was expecting louder than the newish Bosch we took out (and the dishes come out cleaner, too) but this is loud enough that it's a little uncomfortable to be in the room. I wouldn't be against trying to replace the bearings myself but wouldn't know where to find instructions for that.
If the main pump housing is anything like my KDC19, the top housing is attached by 4 screws.
Lifting that top off, the O ring may be bad. upon replacement, I'd put a thin bead of Permatex RED gasket sealer in the groove that it sits in, and then a thin bead where it mates to the bottom.
The Permatex is in auto stores, and can withstand over 600 degrees.
Leave it cure for at least a day or so before running the machine.
I did mine that way a while back.
ALSO: the rubber hose attachment on the left side of the bottom inside goes to the top spray arm, put a smear of Permatex around the rubber opening for insurance - mine leaked because it's made as a press-fit, dry, and prone to leaks.
Yes
They are noisy but you can tone it down by adding insulation. I use this this stuff and staple is to the roof, sides, and back of the dishwasher cabinet opening.
https://www.homedepot.com/p/Everbil...diant-Barrier-Staple-Tab-24x25RI-SE/315103185
You can also add insulation to the lower panel and even the black kick panel of the dishwasher. If you're a person that's tedious and patient, insulation can be added behind the front panel, just be careful it doesn't affect operation, like the detergent doors, by meticulously trimming it. Not only does this reduce noise, it helps retain heat in the tank and fires the machine off sooner during the heating phases.
When you get the parts, I'll help guide you through the process.
Yes
Dan, you are always willing us members out. I appreciate you!
Noisy KD 20 KitchenAid dishwasher
If the noise is loud enough that it’s uncomfortable to hear you’d likely have a bad motor, adding insulation is always a good idea both to keep heat in and to make it sound better but if it really is loud enough to bother you, you should be dealing with the motor.
A lot of times the motor bearings will get Noisy from the shaft seal leak but if you fix the leak, you can go on using the machine for a long time often Noisy ball bearings in these KitchenAid motors will keep running for years but it’s still not the way it should be of course.
Yes
Thanks so much for the offer! It looks like I'll have the seal and impeller kit in a few days, and I can get the Permatex locally. I'm not super worried about noise because it's a closed kitchen and we can usually run it when we're leaving the room. I also have some rockwool up in the attic if that is worth using.
Don't use any sealer that isn't food safe, it's a good way to destroy your health. There are stories of people using a marine sealer in their dishwasher and killing off their entire family.
If the cover seal looks worn, replace it.
You definitely don’t need any type of sealant on the pump cover gasket, and of course you should be careful to use things that are safe to use near food inside a dishwasher.
I would love to see one of these stories where a whole family was killed off by using marine sealer in their dishwasher however, I think that’s a bit of a stretch.
John L
John L
Don't overthink things, there's no digestable food made in a dishwasher. 😠
Yes
Hi Dan, we got the seal and impeller kit and installed it yesterday, but it's still leaking. The instructions I found were not for the same model so I'm guessing we did something wrong.
Reply number 15, yes, GE silicone sealants used to have arsenic in them. It was removed a long time ago when I was a little kid we had a neighbor that fixed an aquarium using GE silicone sealant, and it killed all the fish immediately.
One should definitely be careful with what they use inside a dishwasher this guy that was trying to fix the GE dishwasher must’ve used a lot of that sealant to make the family so sick, it’s too bad. They didn’t take GE to court. That’s a very serious problem.
Apparently they just wanted to be done with it and settled for 25,000, they should’ve gotten a lifetime of medical care minimum.
We used to have to replace the sump in GE dishwashers when it would rust around the edge and you had to use an entire tube of GE silicone sealant the GE supplied for the purpose But this was in the 80s and the arsenic had long since been removed from the product.
John L
The Permatex "Red" gasket sealer that I used on my leaking KDC-19 is rated for over 600 degrees.
And anything staying under 300 degrees, the Permatex remains inert, and safe, once it cures.
