Hey all!
It is apparent that I have too many odd sized objects that I want to cram into my KA and am wondering if I can use commercial standard plastic racks like the ones from Vollrath or something like that? I need a rack with no tines.
The vollrath's I've been looking at supposedly measure to 19.75" square, my rack measures wheel edge to wheel edge 20" if I am measuring it correctly... I need 1/8th inch on each side... Unless the 19.75 will fit? Has anyone tried this? Or does anyone know of a carrier I can use to hold the rack?
I suppose I could always order the racks and see if I can find a way to mount pegs on it or something so the rack can slide?
I am too used to loading a commercial washer rack to the gills and haven't quite adjusted to this rack... I'd probably order a rack with tines as well.
I still am hoping the part numbers and what-not pop up for that Undermount Hobart wash-arm conversion, I hadn't used my DW for a few days and when I did last night, the wash arm wouldn't spin.. I took the arm off, put it back on and it spun freely... something must have gotten in the bushing or something, but I have a feeling the arm is going to need replacing at some point... The arm feels like there is a slight bit of play while on the peg and the one from my donor machine is cracked...
With all of this said, I am surprised with all the SubZero and Wolf type appliances on the Market (brands made to mock commercial equipment) that someone hasn't made a consumer dishwasher that uses commercial racks... If I could find a machine like an under counter hobart that would let me use general consumer grade cascade and had a dry cycle, I'd be all over it.
