lordkenmore
I have been having problems recently with the Kenmore belt drive I use. It is having trouble going into spin. At these times, the motor seems to be running, but the belt does not move.
I had this problem a few months ago. The belt turned out to be loose, and the problem went away when the belt was tightened. That is, it went away until now.
It could, I suppose, be simply need of a new belt. However, I wondering if something else is possibly wrong to cause this belt to decline from working OK a month ago to marginal now. I noticed that when it "sticks" moving the belt by hand (with the machine off, of course) is hard. Move it a bit, and then suddenly there's a slight cracking click, and it moves more easily. Is this normal--stiffness a functioning belt can handle? Or is this a sign of bigger troubles?
