Hello everyone! Hope everyone's new year is off to a good start.
I was just given a 22 year old Kenmore DD washer and dryer set. I have started working on the washer. During my test usage it shook all over on spin up and the cabinet seemed slightly loose. Last night I removed the cabinet, cleaned up the machine really well, removed all of the pet hair under the tub ring and outer tub buildup (yuck) I have a new pump on the way as this one is leaking. I put the cabinet back on and have the machine back together. I still have the bad shaking on spin. It is leveled left to right. the back sits slightly lower than the front but has the self leveling legs. When it starts shaking so bad I can open the lid, grab the cabinet and push it back about 1/4 of an inch and this helps the shaking signifgantly. I am pretty sure that i have the cabiet back onto all of its tabs, does anyone have any suggestions?
I also noticed that the front lip of the cabinet that goes under the base had a notch on each side of the front and a piece of yellow tape above each notch. When I picked the cabinet up to reattach it to the machine, this metal thing in the pic attached was on the floor under the front of the cabinet. What does this go to? Or is it just a spare part? I have'nt seen this mentioned on any of the research I have done about WP DD cabinet removal and replacement.
Thanks for the advice.
