The past few months Ive noticed the landlords Kenmore drier has been taking almost twice as long to dry a full load of clothes. I set the timer on "More dry " and check on it every 30 minutes instead of leaving it an hour and letting it do its thing. The timer slowly advances to " Less dry " and will shut the machine off if I dont check on it but the clothes will still be very wet. One thing that helps is if I clean the lint screen every 30 mins. Even the slightest bit of lint build up seems to make the drier think the clothes are dry and will end its cycle way before its time. Last night the clothes took 1.5 hrs to dry. Could the vent tube be clogged with lint or is it maybe the felt gasket around the tub is causing air to escape and not be pulled through the tub and out the vent? I know the drier is getting hot as hell inside because when the clothes are finally dry and I remove them before it shuts off they're hotter than hell. Here are the specs on it. Im assuming this is from the 80's? Back then my family has this same drier only in gas. Thanks.
Mod. 110.86862100
Ser. M74502633
68621
Mod. 110.86862100
Ser. M74502633
68621
