My mom has a Kitchenaid Imperial (WaterSaver IV) dishwasher which was installed in the late 70's maybe even very early eighties. She has hardly used it over the years. Basically it was used around the holidays and even then, very sparingly.
During the last few years, after she would finish loading it, put the detergent in, and then start the machine, the pump would activate for the usual few minutes, then stop and "seem" to continue on in the cycle. The cycle would last for more than 2 hours. She said this was normal and "it's the way it always has worked". Well, she finally has listened to me and I have told here that I have reasone to believe that the timer may be shot because, if you choose to advacne it becomes very difficult to turn once you pass the dry cycle. It seems to get stuck and you have to open the door to bring the dial/pointer back to the start position. the Sani indicator light comes on and stays on forever....what seems hours later, you hear a sudden whoosh! The rinse and wash cycle has finally kicked in.
My question is this: How can you know for sure that timer is shot? And, how much is a new timer and are they still available? How easy are they to install on your own?
Thanks!
Louis
Thanks!
Louis
