repairguy
I looked at these a couple of times on varagesale and kept telling myself that I don’t need anymore washers or dryers. I wasn’t sure exactly what they were because the pictures only showed the inside of the machines and the tops of them but no control panels. I guess that’s why nobody was asking about them because they were reasonably priced. The description did say heavy duty Kitchenaid. I’ve always wanted a set of these but they weren’t common around here even though we had a sears store for almost 40 years. They are in pretty good shape for the most part. Looks like they were maybe low use machines and taken care of. So I finally told myself after they had been for sale for about a month that I’ll go look at them. They were older than I thought they would be but I really like these control panels. I decided to remove the tub to clean everything and noticed the water pump was new. For as nice as these machines are on the outside the base had more rust than I thought it should so I was thinking the tub seal was probably leaking and since I already had the tub out I might as well remove the outer tub and put a new seal in. When I removed the outer tub the tub seal had definitely been leaking. I think that’s probably why the pump was replaced. After cleaning everything up and putting it back together it was time for the first wash. Noticed it didn’t seem to fill as fast as it should have and then I noticed a leak which turned out to be the hose on the bottom of the water inlet valve that had been replaced. So when I was going to fix this leak with a new hose clamp I found a better fsp valve that I had and installed it. Leak fixed and much better water flow. The washer is probably the lowest model built by Kitchenaid but both are much heavier and built better than the direct drives that I normally repair to sell. The porcelain tops are awesome. Dryer works good but has a little rear seal noise so I might go into it and take care of. Sorry for the story. Here’s some pictures of the machines and some during the washer cleaning and repair. One last note. I was surprised to see the washer still has the original drive coupling and it’s in great shape. Washer model: KAWE550VAL0 built 43rd week of 1989, Dryer model: KEYE750VAL0 built 30th week of 1990
