Re: Lady Kenmore 80 Series Pod, Water Level Control:
The Lever at the bottom of the Console, just past the Washer Lid is the Infinate Water Level Control. I've seen and had several of the same year Washer, although I've never seen this particular Lady-K Model. Some Friends of our Family had a Lady-K Washer that had Plestic Molded "Rocker" Type Controls, that would be pressed on the Upper part for some of the Cycle Selections, according to Garment Type and you would press the Lower part of the Rocker for the rest of the Cycle Selections, again according to the Garment Type being Washer. When you pressed the Rocker, the Timer would "Rapid-Advance" until it came to the hole in an internal Plate with a Part holding Rods with a series of Pins at the ends in front or behind the Plate, the Timer would lock into the Cycle Selected by this action. It was similar to the Manually turned Timer on my Parent's 1968 Lady-K Washer for setting the Cycles and Options.
Peace and Happiness, Steve
SactoTeddyBear...
