Non Agitating KM BD Washer
This is a very easy problem to diagnose, when the washer is full of water and trying to agitate is the agitator bolt moving back and forth ? If so the agitator is stripped loose from the agitator shaft and you need a new agitator.
There are many different agitators that will fit this washer.
The problem is going to be getting the bolt out of the agitator shaft [ it may have to be broken off and then drilled out and the hole in the shaft re-tapped, and the AS may be rusted in the spline area and you will need to pull the transmission to replace the agitator shaft, now you are getting into a big job.
John L.
John L.
