Lady Kenmore Washer/Dryer Combo!
Todd
If your pick up tail gate can be released from the cables/arms
that supports it in the open position, removing said connections will make the gate a ramp at about a 45 degree
angle to the bed, giving more support to the upper end of
your plywood ramp (you need only use one of the halves for
your ramp). If your truck is newer use a padding of some sort
between the tail gate and the bumper to prevent marring the outside of the tailgate; (be sure to wear white gloves, a white lab coat, and paper hazmat booties too. ;> . !!!!)
Washerlover. i', jealous. these are beautiful units. Yake care of them or i will track you down and confiscate them from you. My siggestionm in the moving of them would be a combonation of what all the other posters have said. Use straps. bailing wire underneath to secure the trannie, and lots of old blankets to protect the fine paint on it. nothing worde than getting home with such a fine set only to see gashes in it. Once again, you go boy. and if you use bailing/mechanics wire, double otr even triple it by puting equal lenhgnths of wire in a drill and twisting them tighytly together for a better stronger peice of wire. good luck. keep us all posted on your sure seccess.
Well, we had a successful trip to pick up the new addition to my family. It is in pristine condition, and indeed a 1965 model. It is a beautiful machine, no problems moving it and thank you all for your advice about the thumb screw! No time to play with it now as we are in the process of buying another house, but will post pics as soon as I get her situated in her new home!
The ad says it needs work...........
Did the seller tell you what the problem is, or what was not working?
It's just stunning! I look forward to a more detailed condition report and photos!
Kevin
