When I first started collecting and fixing washers around 1981, the first machine I got was one very much like this one but it was avocado, had the lighted dial, and had a second rotary switch for a sudsaver.
I was so excited to have it (I was 12).   It had black rubber drain hoses with a wire that wrapped around most of the hose to keep it from kinking and an aluminum goose neck on the drain hose.  The suds hose was your typical long goose neck hose with the plastic cross/spacer at the opening.  The two inlet hoses went into the machine and required removing the wood back to be able to exchange them.
