christfr
well while on the search for the smaller of the two bellows i was reminded that there was an o ring as part of the seal under the cone. so on a test i found a ring to fit and put it all back together with a little sealer to see if it would stop the leak .. but no it did not. here is my question the machine will not leak when just full of water and not running or it will not leak when spinning out it only leaks during agi. is there a water seal or carbon seal under the tub that could cause it to leak during agi? or is it just the smaller of the two bellows? any ideas out there?? i want to get this machine back and running so tim can start his collection. please if anyone has an idea or cure let me know id be so so grateful... thanks so so so much
