A little different in the Oasis...
This is with a small load and 2nd rinse:
2 second spray, like the Cabrio (warning for children playing inside)
lid locks
fill through main spray until tub floats (not always water in tub)
wash plate rotates checking tub position and resistance
fills for 30 more seconds, then fills through detergent dispenser
washer pauses, wash plate pulses to measure resistance, determines water level
fills to set water level, starts fast agitation, measures resistance
washer adapts F&P SmartDrive technology and adds water if required
agitation slows, and re-circ spray on for brief periods of time to filter lint
wash continues according to soil level set, with the re-circ spray running briefly from time to time
neutral drain, and cold shower for 2 revolutions
motor revs up to around 300 RPM for 3 minutes
spin stops, and another long cold shower for 10 revolutions
motor revs to 300 RPM for 3 minutes
spin stops, cold shower for 4 revolutions
motor revs motor revs to 300 RPM for 3 minutes
cold shower for 4 revolutions, then a 400 RPM spin for 5 minutes
softener dispenser flushes twice, then fills with cold water through softener dispenser and main spray
normal-speed wash action and neutral drain, brief pause to rinse out re-circ spray tube
motor slowly steps up to 1050 RPM, where the max RPM lasts only for 3 minutes
motor applies electronic braking, tub coasts to stop in about 30 seconds, pump removes last amounts of water in tob, the the cycle is done
HTH
