MaytagA710
- Joined
- Apr 26, 2011
- Messages
- 422
Here is a topic most of us don't really put much effort in to! PUMPS!
They are the life blood of many machines we adore, especially washers and dishwashers. Some could argue the blowers on dryers are pumps, but for the purpose of this thread, we will discuss pumps that move water and whatever else that is in them.
There are two basic pumps I have discovered are featured in appliances, centrifugal and turbine. Both types are different in many ways, and each has its own set of advantages and disadvantages.
The pumps discharge is known as pump "head". Some pumps are known as 'positive displacement' pumps, and others are not.
First, lets start off with a Centrifugal pump.
Centrifugal pumps intake into the centre of the impeller (or the eye), and discharge through the side of the pump. They use the side of the casing to turn the velocity generated in the pump, in to pressure. Centrifugal pumps are not positive displacement pumps. This means that if you were to close off the discharge, the pump can keep going without any issue. Although, eventually, the water around the impeller would heat up as it is friction on the impeller, and it would then heat the bearings up and eventually destroy the pump.
An advantage of this style of pump is that debris don't really have to be broken into little bits like in a turbine pump. In other words, dirty dish water from dishwashers can be handled in these pumps.
A huge disadvantage is cavitation. Cavitation occurs when the pressure of the liquid drops below the pressure point at which the liquid will turn into a vapour. In other words, if the liquid will turn into a vapour at 20psi, the liquid has dropped to 15psi, and has now become a vapour/gas. This causes bubbles, which will collapse when they enter an area of higher pressure in the pump. This causes excessive vibration and wear on the impeller. It can only happen on the intake side of the pump.
Contrary to popular belief, GE DWs feature a classic example of a centrifugal pump. As you can see in this picture, the intake from the sump goes directly into the centre of the pump. The impeller then flings the water outwards, where the velocity is converted into pressure along the volute casing. You can see this as the side of the pump casing seems to get wider as it goes up towards the top, and makes it look like the motor sits offset of the centre of the assembly.
