LG FL Needs more water
pullmyfinger
Active member
Nov 21, 2010
29
Hello all,
Has anyone ever taken apart a late model LG front loader to see what is used to measure water level?
Like many others, I want more water used during the wash cycles. My model, WM2501HWA, has an "Add water" option, but it still is not enough for really muddy/dirty loads.
I can add water to the detergent drawer but the water level sensor cannot be fooled, and stops the cycle and pumps out the extra water.
Anyway, I want to see if the water level sensor can be modified to allow more water use.
Thanks guys!
Wow, that is a real drag that it will drain the water you add. At least my Affinity is too stupid to know better and lets me add as much as I see fit but I have to add it via the detergent drawer too, which is a hassle.
LG, amongst others, uses a digital sensor, which cannot be adjusted.
How about adding a pre-wash and extra rinse? Or a warm Rinse/Spin (with low spin speed) before the actual wash cycle?
I think the only way to add more water by default is to increase the length of the hose that connects to the water level sensor. This will make every fill higher. Don't know by how much the hose would have to be extended, though. It's K550 on the pic below.
Alex
Thanks Alex, good info. Is there a link you can provide to these parts diagrams?
I believe adding to the length of the hose may be what is needed to "fool" the sensor. I will try it and post results.
On my Samsung, I just pause the cycle, open the door, and pour in the extra water, using a pitcher. Then close back the door, and press resume, and that's it. and every time you open and close the door, the machine adds a little more water by itself before resuming the tumbling.
This may or may not help with the LG question.....
I have a KM Elite steam washer and it too has that electronic water level sensor. I have thought about adding an "air chamber" (like a 16 oz or larger plastic water bottle) in the hose via a "T" between the air bell on the tub and the W.L.S. According to other postings (now in the archives) this will effectively increase the water level without the washer going into "freak out mode" and draining the tub. I have yet to attempt it because of other projects and no prepping for my up coming Dec 11 wash-in.
BTW Rob... I love your screen name, VERY funny!
Kevin
when i had my 2007 LG front loader it would do the same thing, pump the water out, i used to sometime put it on the comforter/bulky items cycle, that cycle uses alot more water. although my machine would only let you select the highest spin speed of medium on the comforter cycle.
I typically use the Permanent Press cycle for all loads - including my temp-boosted white loads, and find that the cycle provides enough water to get the job done beautifully, when I also select the "Water Plus" option.
I used to add water through my detergent drawer until I started using this cycle. Good luck!
How to get a Service Manual for WM2501HWA?
I went to the Sears link in reply#6 and I see they have as service manual; *BUT* it says:
Technician Required for Ordering. For assistance please contact 1-800-4MY-HOME or click here to schedule an appointment.
So can morals buy as service manual without being a tech?
Sears will not sell a Service Manual for WM2501HWA
In Calling Sears "parts" for the manual today they said they could not sell me a manual. I talked to 5 different folks in 3 dept's.
"Parts" sent me to "service" and then to "customer care", all who cannot order Sears part # G004 on the diagram Service manual
Number: MFL30599142 $27.69 in stock.
Last night it said backordered; today it said in stock.
Thus here too I wanted to understand more about my new LG WM2501hv washer's water level by buying a service manual, sears has one but will not sell one to me. Weird
I found a manual for WM2501HWA
I googled the service manual number of MFL30599142 and found one at partstore.com for 39 bucks; with tax and shipping it would be 50 bucks ie pricey. I will ponder the purchase.
