lg front load inner workings
gelaundry4ever
Nov 18, 2014
4,559
Temple, Texas, USA
Hello everybody. I was wondering what the lg washers look like on the inside. What kind of suspension system does this washer use? What do the drive motor, pump assembly, steam generator and various parts look like? How do they operate? What do all the models look like on the inside particularly the wm2487? Do they use bearing oil or no. I understand that they were made in Korea. I would like to get a better understanding of how these washers are built so I don't always feel too uneasy of what seems to be flimsy quality. Thanks.
LG...
I have seen two types of motors used in LGs: belt drive with a brushed"universal"motor and some models with a direct drive electronic driven motor-direct drive is much quieter and allows special wash motions on certain machines.The direct drive motor consists of a drum about 10"diameter with magnets around the inside of the outer rim,a stator rimmed with electromagnetic coils fits inside the drum and is mounted to the outer tub.There is an old thread on here where a badly corroded spider is replaced on a direct drive LG-thread title is something like "meet horsey"Corrosion of the spider-usually of cast aluminum-is a common problem with front load washers,often a "death failure"with these machines when the spider corrodes and breaks-a variety of factors determines the severity of corrosion from minimal to severe.The pump in an LG is the usual wet rotor permanent magnet "magnetic" type.LG is made in Korea,started selling goods in the US~1982,selling mini fridges and small black&white TVs under the "goldstar"brand :) No bearing oil-just greased ball bearings.
Google is your friend
Seriously Jerome, do some internet research. All these parts you want to see are readily available on the internet and Youtube.
Look up repair videos. Search for LG and Samsung patents in Google Patent search.
Look up repair parts via a model number search on RepairClinic.
I've been feeding my curiosity this way for years.
Why do you expect us here to spoon feed you EVERYTHING?
Go onto the internet and look up "using a washer motor as a power generator powered by wind or falling water"That may give you an idea what the DD washer motors are like.And these power ideas actually can work.So--some of the "scrap" value of DD washers is in their motors "recycled" for small power generators.Hint-go to a place selling the DD washers-LG or Samsung--Give the drum a good spin-the washer dial lights will come on breifly and it will play a tune--The store salesmen love it when you do this-gets their attention!!
Some advice...
Go to your local hardware store and purchase a set of tools. You can tear apart a machine completely using a decent screwdriver set with torx bits, a socket wrench set and maybe an anti-tamper screwdriver set. (At least, I did with my old FF. I'm not sure what other tools one needs with modern machines, but that's a start!)
Then go onto Kijiji and find very low cost or free machines. Maybe a used appliance place might have something you can tear down for parts.
Then just go to town. That's how I learned. Don't worry about breaking anything. It's easier to tear the machine down than it is to put it back together, which you probably won't anyway. :-)
There are service manuals on the net that show how to tear the whole thing down and put it back together, step by step. You know you are doing things right when you can put it back together, not end up with any extra screws and it works. :-)
There are also really good youtube videos online that show how to do a trunion bearing replacement for Whirlpool and GE washers. They literally have to take the entire machine apart in order to get at it.
There are massive amounts of youtube videos out there that show all of the basic concepts you need to know. Although, nothing beats getting ones hands dirty!
Slowdown folks, we are dealing with a young man here and we need to take our time to show him the rope!
This maybe his first major message board participation that he has joined and it takes time to learn and understand how it works...
Some message boards are complex or inefficient with data that makes even me go crazy, take a moment and remember how we all got started!
I've seen a recent Hozzer (THS/GardenWeb) thread who was former member of this site who is still bitter from what happened in the past wrote a nasty gram about AW.org..
What enter the internet, stays on the internet for life and viewed by millions.
Thinks about it?!
Share and post links to help those who not tech savvy!
spinning the drum on a late DD GE...
I spun the drum briskly on my 2012 Chinese made 24"direct drive GE and nothing happened-have heard many times LG DD s will light some of the indicators if spun.
What happens on my Fisher & Paykel direct drive topload washer is this:
1) If there's a load running and a power failure occurs during spin, the motor will generate enough power to keep the electronics on and the lid lock engaged for safety purposes until it coasts to a stop. Then the machine turns off and remains off until power returns and the cycle resumes where it stopped.
2) If there's a load running and a power failure occurs during any operation other than spin, the machine simply stops and remains off until power returns and the cycle resumes where it stopped.
3) Rotating the drum by hand when the machine is off does not cause the controls to turn on, but if rotated fast enough the motor may energize into a braking mode.
This was a few years ago when I did the drum spin thing in the LG and Samsungs-will have to try it again and see if the design has changed.Spinning the drum doesn't turn the machine on-the motor acts as a generator and breifly powers the electronics until it slows down and is no longer generating electricity..PM motors will become generators when turned.This can make them useful as generators as well as motors.
The LG s still lite up but go off as soon as the drum stops. I do, it at Home Depot to show the customers as the salesmen watch in amazement. If you go to Facebook, I have still photos of the disassembled 2277 Steam model. I had to replace the barings,tub seal,inner tub,outer casings and pump. I found it in a trash heap free. I sold it for $750.00
Yes,like the floor nozzle of a Kirby-a simple electric generator.The brushroll has a small magnet that goes past a coil of wire connected to a LED.When the brushroll spins at the right speed-the LED gets enough voltage to light.
There are some videos on Youtube
Where they use a F&P top load drum and motor as a waterfall generator.
Electric motors are just generators in reverse.  It's a way of transmitting the mechanical energy converting it to electric energy and converting it back to mechanical energy.   (whew, I'm glad I was awake that day in Physical Science class).
How does the machine know when to turn on the circulation pu
Through the machine's electronic controller.  They actually control everything, this is why they are needed because many of the operations the electronics monitor and control are far beyond the abilities of older mechanical timers.  If the mechanics were able to control everything they would be so large and complex that their cost would outweigh that of the machine.
The computer control board changes the electric current to the motor for which direction to turn according to the cycle program sequence.  The pump is a separate circuit on the control board.  The microprocessor turns that circuit on when the cycle sequence calls for circulation.  Simple.
water level and suspension
What does the suspension system look like in the lg front loader? How full of water is the outer tub if I barely see any water? How does water saturate the clothes if I barely see water after filling and before circulation starts? I am talking about when tumbling.
Why have some of you guys got to be arseholes? This is a washing machine thread. You guys are supposed to be experts and enthusiasts. Believe it or not you can't find absolutely everything about everything on the internet. There are a handful of videos which show bits and pieces. Maybe the guy was thinking some of you had pictures, being technicians of machines and so on.
These forums are so hostile at times.
Just look at some of the other recent posts on this forum lately...
This is one of the most helpful and friendly forums I have ever seen. People go out of their way to post cycle guides and other detailed info, but it doesn't seem to matter. If there is hostility, there is a good reason.
<blockquote>I have to wonder how the computer tells the machine to add water in short bursts. Why does it do this?</blockquote> The cycle programming embedded into the logic chips on the board controls every aspect of the machine's operation ... just like Windows or whatever is the operating system on your computer or phone controls its operation. A water level sensor, same as on any other washer, monitors the water level in the tub.  The control board adds water until the sensor registers the correct level.  Filling is done in short bursts to give the tumbling load time to absorb water and get saturated and minimize the need to add more water later.  If filling was done very quickly, the water level in the tub may register as full on the sensor before the load is fully saturated.
<blockquote>What does the suspension system look like in the lg front loader?</blockquote> I don't have an LG to show its construction but perhaps these pictures of a Whirlpool Duet will help clarify for you.  I imagine most frontloaders have a similar suspension arrangement.  The tub hangs on large springs at the top and is supported and cushioned by hydraulic shocks beneath.  You can see the two shocks beneath toward the front, there are two more at the back.
<blockquote>How full of water is the outer tub if I barely see any water? How does water saturate the clothes if I barely see water after filling and before circulation starts? I am talking about when tumbling.</blockquote> These next pictures show with the front half of the tub removed how much space is between the outer tub and inner drum on the Duet.  There's a deeper sump area at the bottom which of course has to completely fill with water until there's enough to reach into the drum.  The water heating element fits into the metal clip at back of the sump.
Another view of the drum and tub.  Water saturates the clothes by way of the fill flow spraying directly onto them if the machine's design does that, and by the clothes tumbling through the water as rises up at bottom of the drum.
Dadoes
I wnnt to say thank you,  very nice visuals.  I actually own one of those machines, and since I have never had it apart; did not actually know what the innards looked like.  .
Very nice--Thank You
