Bob, What a colorful load of dishes, but then you always did set a fine table. I love to display original Fiesta ware in old dishwashers with a circular lower rack. I am going to explore rigging up some sort of wash arm under the top rack in my Maytag portable. The model right after mine had the gray tower in the lower rack with that round spray head. That had a feed from the lower wash arm hub that might work for a wash arm under the top rack. If nothing else, I might keep it as it is, glue closed the holes in the tumescent tower, cut off the top and have it feed a wash arm under the top rack. If there is not enough pressure for that to work well, I will start closing the holes in the wash arm at the top of the tank. It's fun & frustration seasoned with a bit of insanity here at Frankenstein's Appliances.
