Longest Main Wash Time
Chetlaham
Mar 11, 2013
4,237
United States
What dishwasher had or has the longest main wash cycle? Seeing GE dishwashers with a default 56 minute main wash got me thinking, excluding overnight wash cycles, how long has the main mainwash gotten? Also, how are these long cycles not etching dishware?
Wasn't there a Whirlpool dishwasher that had a 4 hour light wash cycle, 8 hour normal cycle, and 12 hour pots and pans cycle? I faintly remember that being discussed in the forum years back.
One has to keep in mind that US rating of noise levels (or more so the measuring standards) appears to be somewhat different than the EU rating system.
Bosch had 38dB machines in the US while we had exactly one of those over here and that was a specific edge case.
But the VZugs come in at 38dB or 42dB respectively when we're talking the heat pump version (which surprisingly is overall faster, but only by like 30min or so on the Eco cycle).
When I had my point voyager KitchenAid, the model above it had an over night Soak and Scrub cycle. I don’t remember the exact sequence, but the Prewash lasted 6 hours, and would spray for something like 10 minutes and the it would sit for the rest of the hour. The rest of the cycle would progress as normal.
I have a newer GE portable made by Haier. When the HI TEMP wash is selected, the main wash is over 60 mins. Absolutely absurd. There’s no reason for that. I’ve opened the dishwasher up in its first pre rinse cycle and everything was totally clean, there’s no reason for it to run so incredibly long. It’s makers have no idea what their doing when it comes to programming the times on each cycle, if they actually had tested their own product they’d know an hour wash time is ridiculous. I always use the light wash which is under an hour long. This is the type of dishwasher that runs all arms at once.
Glad someone mentioned this because it’s been on my mind for so long, why are new dishwashers SO OVER PROGRAMMED!?? These machines run so long while spraying clean dishes, most dishwashers clean the dishes fully in the first ten-25 minutes. There is no need for them to run any longer than an hour. Pre rinse, wash, rinse and rinse. Done. Each pre wash should be 5 mins long, each main wash should be a good 15-20 mins long, and the final two rinses should be about ten minutes each, now that would be reasonable.
My GE when set to the Sanitize cycle takes an hour long wash, then another hour and a half to sanitize. You are not gonna tell me it takes that long for it to heat up to sanitizing temperatures, it should be a half hour at most long but that is not what we have here with most new dishwashers. They run forever, and ever and ever, while cleaning already cleaned dishes that were cleaned in the first half hour of the cycle, the rest of the cycle is a waste of energy and water as far as I’m concerned. This is why I love to use my older Whirlpool power clean so much, it’s fast and extraordinarily efficient. No BS. I understand newer dishwashers are weaker, but still, but they can still clean a load of dishes in under an hour no doubt yet all these manufacturers are over programming every cycle just about. This is a dishwasher crisis and I’m glad someone mentioned this cause it’s about time we talk about these utterly ridiculous cycle times where dishwashers are over performing.
When GE added the fine filter to their 1970s design, they reduced the water charge to about 1.1 gallons and to compensate reduced the flow rate of the main wash arm. Coupled with literally plus sized wash arm holes (5 at the top, at least one at the bottom for the fine filter water sweeping) and a ridiculously fast rotation a 60 minute wash time was a given.
But- that pales in comparison to the their tall tub models which literally used a brushed motor IIRC <span class="ILfuVd" lang="en"><span class="hgKElc">🤮 That is literally the definition of blatant obsolescence. You literally have wet rotor magnet pumps, you literally have sine wave AC at the incoming line, you literally have low cost VFDs at your disposal. Yet decide a tiny brush motor is somehow practical for a DW.  I agree, like what were they thinking.
</span></span>
What GE should've done...
What GE should've done was what Bosch did. They should've used similar pumps that speed up and slow down the pump while still keeping the flow of the water going. That's what my Kenmore does, yet the spray never stops.
They've forgotten the basis of electrotechnology at the key to its legendary monster smash success. Have the necessary information for rotation, induction and timing delivered from central location instead of produced within the appliance itself. Nothing is gained tossing out the timeless simplicity to then re-invent a much more complicated, expensive and trouble prone wheel. Its like blocking out the sun via a giant wall around a home, then trying to re-create the sun in a cold fusion reactor deliver its artificial light output through the same windows the sun would otherwise have shown through.
